water in my headlight
Old Nov 7, 2006 | 01:42 AM
tcridinclean's Avatar
1UP Crew
Default water in my headlight
a little water seeped into my left headlight because the parkinglight socket wasnt closed all the way tight (stupid mistake) and i got a lil bit og water on teh glass on front of my turn signal how do i get rid of that water there?
Old Nov 7, 2006 | 02:14 AM
imsonofagun's Avatar
Lazy way is to let it evaporate on it's own. Something more involved would be to remove the light assembly, try to shake out as much water as you can, and either bake the assembly at a really low temp, or use a hair dryer or heat gun to speed up the process. Other than that, not sure what else to do.
Old Nov 7, 2006 | 02:23 AM
mike6789k's Avatar
take out the headlight and stick a towel in there then pull the towel out...
Old Nov 7, 2006 | 03:45 AM
Neothin's Avatar
yeah, a towel will work fine.
Old Nov 7, 2006 | 04:09 AM
Dakine's Avatar
Concept in Motion Crew
where u gonna stick the towel?
Old Nov 7, 2006 | 04:10 AM
Neothin's Avatar
through the highbeam socket (or the low beam socket, i cant remember which one the parking light is in )
Old Nov 7, 2006 | 04:50 PM
Sniffs's Avatar
just drive around with the lights on.. the heat from the light should dry it pretty quickly
Old Nov 7, 2006 | 04:54 PM
Bobby_Lee's Avatar
Ronin Scion
If its warm and dry where you live, I'd just pull the bulbs out and leave the car in the sun for a while (water will evaporate on its own). I wouldn't suggest using a heat gun, though. I tried that when I had the same issue and it almost melted a hole in my housing...
Old Nov 8, 2006 | 01:08 AM
mike6789k's Avatar
if you let the water evaporate, it will leave a waterspot... EWWW
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Btp907
Sep 11, 2015 11:46 PM
