0-60 w/SC
Grip won't be as big of an issue as with turbo. With a turbo, almost all the boost is delivered in a span of 1000 rpm versus a super delivers boost over a span of 5000 rpm. The power won't overload the wheels as it would a turbo.
That's the nice thing about superchargers that people almost always overlook. It's also the bad part - people complain about the slow power delivery. The slow power delivery would somewhat be akin to the wider gear ratios on factory turbo'd cars that allow looser ratio so as to not start the wheels spinning from the get go.
Who knows, the TRD supercharger might be worth it after all. I just remembered this part of superchargers. Since you can work with more grip and sooner, you can launch at 2000 rpm (probably) and floor it from there all the way through whereas the turbo requires some feathering of the turbo until third gear. In this way, the manny tranny seems to be geared towards the supercharger while the longer gears of the auto may in fact be better suited (with upgrades of course) to a turbo.
Who knows, we may yet be surprised by the TRD supercharger.
A centrifugal SC exhibits lag similar to a turbo.. so the same issue will still be there with the boost delivery, just not as bad.
A roots or screw type SC is more linear as described above, but unfortunately is not being used here.
Strictly Scionized
I"m sorry just with that, have you ever driven a turbo'd or SC car before????
You've got the right idea, but you're wrong in a couple ways:
1) A properly sized turbocharger will start boosting at low rpm, and have a nice fat powerband. This seems to be the case with the turbo kits which are out for our cars right now.
2) The centrifugal-style supercharger that TRD is using acts much like a turbocharger in that it doesn't start making power until it really starts spinning. The powerband is very different from roots/eaton style blowers.
Well said on all accounts. Also, the S/C might be easier to modulate around corners and on the straights where ruts are in the roads since the turbo will be forcing the wheels harder down low.
I'm definately interested in the results of the S/C.
Originally Posted by TheQuietThings
of course it will still be a problem. most of us now, without any kind of forced induction have traction issues when starting from a dig. The problem isnt what kind of forced induction, its because of our drivetrain beeing FWD.
2. Even though the s/c acts like a turbocharger, it still makes boost a lot slower than a turbocharger. The dyno for the s/c shows a steeper slope but less overall power than ZPI's turbo which shows a flatter slope but impressive amounts of power pretty soon. Regardless of s/c style, the power curve is much more linear and proportional to engine speed. You can compare the ZPI dyno by searching to the TRD dyno here. As you can see, the power curve is still similar to an engine with more displacement.
However, I must emphasize that I'm not stating this as absolute fact. I don't have any experience driving in a turbo or supercharged car and all this is reasoning or .. heresay I guess.
Assuming Toyota's claim of around 200hp, I'd guess 0-60 in about 6.1. Reason for this being: our car is lighter than the Cobalt SS, geared more aggresively, and should be comparable in power (whihc hits 60 in 6.1). As far as traction goes, both cars are comparable for tires.
Originally Posted by duston831
what exaclty is it that makes our tires crappy? the only factor i ever knew were the treads
run some slicks for traction... but on the track only of course
extra power to a tC and still the same unacceptable wheelhop....unless you add an aftermarket engine damper, or fab some new motor mounts.
they honestly want you to be happy with transferring that power to wheels that won't stay on the ground and an engine that crashes back and forth?
