'05 Scion tC clutch issues
My car would not go into gear the other day and I'm not sure why. I sat there and pumped the clutch a bunch trying to build up pressure for it to work. I shut the car off to make sure that it wasn't my actual clutch pedal messing up and the car started when I pushed the clutch.
I finally was able to get it into gear and get home. I thought about it being the master cylinder or even the slave cylinder messing up. I checked the reservoir and I had fluid in it at that time and I checked it again earlier and it still had fluid in it so I know I'm not leaking fluid.
Last edited by MR_LUV; Jan 10, 2018 at 08:26 AM. Reason: Moved to Correct Forum by Moderator
I had my Jeep Liberty 6spd do that a couple months ago, not sure if it was the master or slave that failed. Lucky the only replacements are sealed master/slave with line already bench bled. Our Nissan's also act the same way and are a huge pain to get bled correctly. If you can get or build a pressure bleeder it makes the job so much easier.
