07 + engine on 05-06 tC????
Old Aug 28, 2011 | 07:30 AM
jaybepr's Avatar
Default 07 + engine on 05-06 tC????
Hi, here is my question for today, is posible to install a 07-10 engine on a 06. I know basic is the same engine but the ecu and some internals change, but can i use the 07 + with my 06 ecu & harnes s there any extrasensors or just the MAF change??? Thanks
Old Aug 28, 2011 | 07:42 AM
cmcpride's Avatar
If your only using long block it's ok. The only difference will be oil clearance. 05-06 use 5-30w 07 -10 use 5-20. I'm using 09 on my 05 at the moment
Old Aug 28, 2011 | 11:34 PM
DeAnzaJig's Avatar
yes
Old Aug 29, 2011 | 12:36 AM
jaybepr's Avatar
OK, there is no problem using a 07+ long block with the 05-06 ecu harnes & computer??
Old Aug 29, 2011 | 01:09 AM
StreetSweeper's Avatar
u should be good to go man
Old Aug 29, 2011 | 02:34 PM
Jon's Avatar
Jon
Moderator
Moderator
You should search as it's been discussed several times before.
Old Aug 30, 2011 | 02:35 AM
mrexotica's Avatar
As a tangent, I prefer my '06 tC over my '07. The reason being I race. The rev limiter on the '07 cuts the engine. The '06 has a normal "bouncing" limiter.
'07 is also a bit of an orphan motor, as some parts will fit '05-'06 or '08-'10. '07 was unique.
One more thing then I'll return to the post, the '07 has one more hp.
The '06 has a bit more torque.
VitaminE
18
Jul 2, 2015 08:10 PM
jctc06
Apr 16, 2015 12:11 AM
carid
Mar 30, 2015 07:08 AM
tom0613
Mar 7, 2015 05:59 PM
