201Whp N/A Update **BC Cams Installed**
Old Apr 9, 2011 | 08:51 PM
  #81
BadDudeTC3's Avatar
Looking forward to an update on the cam install and dyno!
Old Apr 9, 2011 | 11:11 PM
  #82
jimmyjun's Avatar
i've been busy working on my friends (2zz engine), hopefully i can start working on mine the next weekend!!!!!!! ill give you guys some updates once installed.
Old Apr 10, 2011 | 02:50 AM
  #83
BadDudeTC3's Avatar
Gotcha, I'll keep my eye out for the update!
Old Apr 12, 2011 | 05:23 PM
  #84
blacktcpa's Avatar
Yo jimmyjun love what you've done so far and I'm trying my best to be on the same path. Wondering if you have considered trying to use the camcon vvti/afr controller? That way you can control the vvti and still control the afr like the apex'i.
Old Apr 12, 2011 | 09:14 PM
  #85
BadDudeTC3's Avatar
Hmm....after reading about the Camcon controller I'm interested in knowing your thoughts on this one JimmyJun. I haven't come across to many people saying that they are using this but then again not a lot of people go the N/A route.
Old Apr 13, 2011 | 12:19 AM
  #86
jimmyjun's Avatar
camcon piggyback is only good for vvti tuning, its a/f tuning abilities are not that good compared to the apex neo or other fuel
controllers, my plans are to install the cams and tune, if i get a cheqp
camcon from mu friend ill use it just to tune the vvti and the neo to tune a/f.
Old Apr 13, 2011 | 03:55 AM
  #87
BadDudeTC3's Avatar
The Apex neo is more robust and can give you data which is a definite plus. After reading the breakdown of what the Apex neo does it sounds like a great way to get even more out of our motor because it has the ability of controlling the vvti.
Old Apr 13, 2011 | 06:36 AM
  #88
blacktcpa's Avatar
http://www.fastscions.com/scion-vvti...ontroller.aspx
says it does a/f? youpositive?
Old Apr 13, 2011 | 06:37 AM
  #89
blacktcpa's Avatar
i guess you could go with both in tandem but i would love if dezod would just show a price for the APR already.
Old Apr 13, 2011 | 07:31 PM
  #90
BadDudeTC3's Avatar
The Camcon does state that it does change the A/F ratio and controll vvti but I guess its all up to preference as to what you want to use. Personally, I like being able to see the data right in front of me and being able to collect and analyze from different conditions so the apex-neo would be more up my alley because I don't necessary have steady access to a dyno.
Old Apr 14, 2011 | 11:58 AM
  #91
XPRTc's Avatar
Call them up and I'm sure they'll give you a quote.
Old Apr 15, 2011 | 02:15 PM
  #92
jimmyjun's Avatar
last time i spoke to dezod i was told 1,500 for the apr unit....
Old Apr 15, 2011 | 03:40 PM
  #93
BadDudeTC3's Avatar
Wow....$1,500 is up there! I'm leaning towards the Apex neo personally. Since it can control vvti & afr with having the capability of giving you live data that's a N/A tuner's dream and definite plus with spending half as much for a standalone or the Dezod apr.
Old Apr 16, 2011 | 06:44 PM
  #94
jimmyjun's Avatar
that would be the apex pfc(not neo) lol!!!
update: the engine is out of the car, we are fixing a tranny issue (3 gear). and cam installement. car shpuld be up
& running by the next weekend.
Old Apr 16, 2011 | 07:33 PM
  #95
XPRTc's Avatar
How much is the Apexi PFC? $1500 is better than when the first X1's came out they were $1800. The unit is pretty awesome with accuracy and precision.
Old Apr 17, 2011 | 06:51 AM
  #96
ScionFred's Avatar
I wonder if Dezod has had the X1 re-calibrated for the TC MAS yet or if they're still using the Tacoma MAS programming and trying to tune around the differences? My X1 MAS signal slope and resulting ECU calculated MAF was off by about 20% due to these differences! The $1800 APR X1 worked like ____ on my 08 XB but YMMV. MAF off by 20%, no rev-limiter and my AT wouldn't shift properly. I sold it back to Dezod for $1200 after wasting several months with it (the best I could get without a lawyer).
IMO the APR X1 has the potential to be the best EMS available for Toyota/Scion but only if the necessary R&D is performed to tailor it to indivdual applications. As-is, it's the ultimate piggy back for the Tacoma trucks it was specifically designed for. Maybe it works better on TCs but it didn't work satisfactorily on my AT XB. Caveat emptor.
Old Apr 17, 2011 | 07:36 AM
  #97
XPRTc's Avatar
Sorry to hear things didn't work out Fred. When I switched to blow-through my MAF loads were spot on. The X1 obviously doesn't affect my shifting because I have a manual. I had problems with heat soak with my FI set up (before I switched to a blow-through set up), but for an NA application I would imagine that wouldn't be a problem.
Old Apr 18, 2011 | 03:14 AM
  #98
LETZgoBUDDY's Avatar
read most of this thread. congratz on hitting 200+ whp. i heard of lots of "can't be done"s and finally someone that can prove them wrong
Old Apr 18, 2011 | 05:29 PM
  #99
ScionFred's Avatar
Thanks, it was very disappointing that it didn't work out. I can only guess that the Taco MAS signal slope and transfer function are closer to the TC's than the XB's. I'm certain that the 20% MAF error was the X1 and not my MAS setup because it works perfectly w/o the X1. LTFTs are where they should be as are measured load and shift points. With the X1 installed, the instant the ECU hit OL and the X1 took over it had to add 20% fuel to acheive the desired AFR. We never did figure out why the rev-limiter didn't work with the X1 installed.
I'm glad it works better for you than it did for me. It's capabilities are impressive.
Old Apr 19, 2011 | 02:11 AM
  #100
jimmyjun's Avatar
thanks!!!!!!!!!!
