2AZ - Orange Virus Tuned.
Old 09-01-2016, 07:54 PM
bbsciontc's Avatar
Wow, that's awesome! BTW, does this enable VVti control?
bbsciontc is offline
Old 09-01-2016, 08:35 PM
MasterZ's Avatar
Originally Posted by MasterZ
I thought I had posted this on this site, but here's a pic of the dyno sheets superimposed in one graph. OEM ECU vs. the OVTuned ECU.
You can get a better picture of where the improvements are, And it's pretty much an improvent across the board!
There's a nice gain of an approximate 22WHP and 27ftlbs of TQ at 4000RPM and almost a 25WHP gain at 5500RPM.
This is nuts!
So pleased that this tuning option came to fruition.
Yes, VVT-i control is one of the perameters of the tune. as well as VVTL-i with cars so equipt.
From their website:
-We re calibrate the ignition timing maps for more power and better throttle response
Ignition timing recalibration (for low/high octane mapping)
Ignition timing compensations (temperature) remapping. Less power loss with heat soak.
-Throttle mapping to eliminate drive by wire "dead spots"
- Fuel mapping to reduce the over-rich targets of the stock ECU
Fueling recalibration. Stock fuel maps are quite rich, and we can maximize torque by safely leaning out AFR slightly while reworking Ignition and variable camshaft timing.
- Camshaft timing and lift (XRS) adjustment mapping
Variable Camshaft Timing and Targeting recalibration
MasterZ is offline
Old 02-18-2019, 12:53 AM
AlphaWiskey's Avatar
If you go back to a stock tune will you pass a vehicle inspection (Massachusetts specific)
AlphaWiskey is offline
SoFloTC
53
11-23-2009 12:55 AM
AcrimoniousBear
04-22-2008 12:51 PM
eliXion
23
07-16-2007 08:54 PM
KCTTC
40
06-28-2007 12:16 AM
audiobahntc
23
01-04-2006 02:40 AM
Quick Reply: 2AZ - Orange Virus Tuned.
