Installed camcon and intake. Dyno inside. *W/ Time slips*
Current Performance Modifications:
Megan Header
Megan S-pipe
2 1/2 Custom Exhaust
Umnitza Carbon Fiber Intake
Custom 2 1/2 Intake Piping
Camcon Fuel/Cam Controller
Pics of intake:
I spent most of the time getting the a/f right as it was running really rich. On the first couple of pulls the a/f ratio was around 10.2 - 10.8 from 3500 to 6500. There is defiantly more power to be found in the cam timing between 2000 and 4500. I ran out of time and did not get to tune the cam timing below 4500. I am going to get back on the dyno in a couple of weeks and finish tuning the cam timing.
I did not get a graph with the stock numbers or the numbers before tuning the camcon.
Stock= 140 hp and 143.6 ft/lbs
Before tuning= 154.2 hp and 155.4 ft/lbs
Dyno:
Time Slips: Car #17
Big Thanks to Mike Murphy of Sublime Speed Technolgy in Omaha, NE for all his time and help.
-Jeremy
Megan Header
Megan S-pipe
Pics of intake:
Dyno:
Time Slips: Car #17
-Jeremy
anyone else runnin camcon? now how exactly does this work as in wiring it in and what not...for as rich as you were runnin those are some good numbers cant wait to see the jump when you tune...you may have started somethin for people that dont wanna do F/I
The a/f is already tuned. I just have to finish tuning the cam timing below 4500. You can really see on the graph where the power picks up at 4500.
-Jeremy
yea thats awesome your goin good...keep us posted once your final numbers are up id love to see it theres still small things u can add for the little extra...ever think of ported TB or intake mani(which i havent come across yet)
Originally Posted by 2_much_tc
where can you purchase this thing called camcon?
i thought that camcon didnt work below 4000rpm due to our smart ECU relearning and adjusting itself? or am i completely wrong?? if so can someone enlighten me b/c i really thought that our ECUs were very smart and always overwritten any changes mad in a non-WOT situation.
thanks
dan
thanks
dan
thanks
dan
thanks
dan
nice torque curve...
-Jeremy
Timeslips show high to low 15's (I'm assuming your car #17). I ran a 15.6 stock before. With all the extra add-ons, why only .2 or .3 seconds improvement?
Also, what kind of tC are you driving where it weights 3400lbs!!!
your definitely leaving room for improvement. with similar mods (you have camcon, whereas i have pullies) i've pulled a 14.96 @ 91.xx get that 60' down! my 60' on that run was a 2.05. your best was a mid 2.3..... your leaving your time at the line
I have since been told that they weigh 2930. Can anyone confirm this number?
Neothin, what kind of tires are you runing and how were you launching your car?
Good call Neo, I was wondering why it was higher then it should be. I noticed however, he started getting his 60's better as he went on. 15.2 is a good run.
I know the slips are hard to read. I don't have the best scanner.
Here are the times:
60'------------2.571-------------2.466----------------2.340
1/4-----------15.901------------15.783--------------15.541
mph-----------90.98--------------87.76---------------32.54
I am not sure what happened with the mph on the last past. I was told it would not affect any of the times.
-Jeremy
