75000 Miles Spark Plug Installation Questions
Disconnect the negative side of the battery for a good 30 mins. I remeber my car did something similar when I changed my plugs. Sometimes when I would stop at lights, the revvs would bounce from 500 to 1500. I think your car is just trying to learn the new plugs. What is the part number on the new plugs?
If you did disconnect the battery cable, that is what caused it. When you reset the ECU, it takes a little bit of driving for it to learn its idle settings again. Perfectly normal and should go away after a bit of driving. It will drive pretty much normal, but when you stop its idle will be low and will hunt a lot.
The car doesnt need to learn anything regarding the plugs.
If it doesnt go away, then make sure your plugs had the right gap for the car.
Guy above, I replaced them with the same stock Densos - exact model and everything.
It should only ever idle at over 1000 RPM when you first start it. Normal idle after it runs for a bit should be around 700 rpm. So it sounds like it was just the reset that you were seeing.
the 2az-fe (scion tc motor) idles between 690-710rpms with slight drops down to the 500rpms depending on engin load at idle(lights on,heater fan running rear defroster even cooling fans ect.....) all can play a part on low idle at times. iv watch this happen on my digital rpm shift light controller i have installed in my glove box
and about differnt idle speeds all motors are not the same some need higher idle speed and some need lower speeds. old 60's big blocks idle around 400-450rpms and top fule dragster idle around 2200-2500rpms. every motor and setup is differnt.
daniinpitt
Apr 4, 2015 08:07 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
