Aftermarket downpipes Question (Need advice/help)
Hey everyone my name is Kate,
I am new to the forum, but definately not new to the car scene(just to Scions). I bought my 2005 Scion Tc about 2 months ago. I have a TRD exhaust and cold air intake right now, though I am getting headers here shortly. I want to also get a downpipe for it as well. However, I am new to scions and I will be going to California for my job and I know without my catalytic converter I will not pass the inspection due to the check engine light will be on. I know you can trick it by putting an O2 stimulator, but I can't seem to find one for it. Also, I know you can trick through the spark plug wires (did that on the civic si), but I am not sure if I can do that on my Tc and have it work. Any ideas of how to make the check engine light not come on with the downpipes once the catalytic converters are out?
Also, I have found downpipes from this website: http://www.tunerzimage.com/Scion-TC-...trdp-stc04.htm
They say it is emission compliant to factory specs. Any thoughts on this?
P.S. I would also like to say, that yeah I have read some forums about how Tcs have become chick cars. I agree, and it is a shame (I am a female by the way), but if the girl knows her stuff, can work on it herself and can actually drive then it should not be a problem. Lastly, those who just want a car for show and has no go, thats when it is a problem and yes that is most girls and some guys even (I see it all the time!) or they get stuff done and have no idea what it is, that is not cool.
Hi,
Unfortunately, the Check Engine Light is the least of your concern for inspection (smog check). California does a visual inspection of the engine, checks the gas cap, and measures emissions from the tail pipes, as well as an OBD. Aftermarket parts, such as headers and cold air intakes have to have California Air Resources Board (CARB) Executive Order number, otherwise, they will have to be removed to pass smog. Removing cat converters is not allowed unless they are defective, and since our primary cat is found on the exhaust manifold, tCs with headers will not pass. If you plan on registering your tC in California, you will be required to have it smog checked before it can be registered.
--> http://www.dmv.ca.gov/pubs/brochures...r9.htm#feesdue
As for the downpipe, or s-pipe as it is called on the tC, it by itself won't affect smog testing. However, if your car fails smog and they check the exhaust system, any O2 sim or spark plug anti-fouler will stick out like a sore thumb. I would highly recommend returning your tC to stock for registration purposes.
If you would like more information on what to expect in California as it relates to your tC, please follow this link:
--> https://www.scionlife.com/forums/viewtopic.php?t=165444
2fast4you,
That blows. I did not know California does visuals. I won't be registering it there, I will keep my NC registration and will get an out-of-state when need it.
I appreciate the info! It helps out a lot, sucks, but helps!
So how do you guys do anything performance to your cars??? And so I am assuming pure white HID's are probably illegal too?
Wait, why is that a problem? not the part about getting stuff done and having no idea what it is-- i know that's typically a "problem" but, why is having a car that looks nice and doesn't have headers or a CAI or S/C, or Turbo etc.. a problem?
Originally Posted by thispecialk
wont it cost more to remove modified parts and putting back to stock then to find someone that will pass u for alittle more money
bootlgr
Jan 26, 2016 01:22 AM
