apexi S-AFC II
Old May 17, 2005 | 05:06 AM
aarontrini85's Avatar
Default apexi S-AFC II
ok so i have my rsm in now and i saw this think its a s-afc II it allows you to tune your car for the mods you add. does any one have one of these and are they worth it? i plan on doing some little things to my tc nothing internal just bolt on's and a port and polished head. would this help alot??
http://apexi.com/product_electronics...=202&pageNum=1
also if any one has directions for the new style rsm in english please send them to me the only ones i can find are for the old ___ one thanks
Old May 17, 2005 | 03:55 PM
uncompiled's Avatar
I've had one before and I don't think it's worth the money. If you end up going forced induction or doing serious modifications, you're probably going to chuck it.
Old May 17, 2005 | 04:00 PM
dgHotLava's Avatar
moved to power hungry tC...
Old May 17, 2005 | 04:16 PM
05-RS1's Avatar
u can use safc-2 on scions?? i thought they only work for hondas. i have it on my rsx with i/rh/e. after dyno tuning, i gained 10whp/12tq. i'd say its worth it if u can find it for under 200.
Old May 17, 2005 | 05:06 PM
that is what i thought that they were only for hondas but i saw one of the sentra guys that is hanging out on our forum has one so i guess there universal this is the honda one http://apexi.com/product_electronics...=201&pageNum=1
Old May 17, 2005 | 05:29 PM
Gmoney's Avatar
Seven City Scions
my question is how do you tune the thing? do you have to have tuning experience in it.
Old May 17, 2005 | 05:53 PM
i guess a dyno would be good and also some thing to let you know the air fuel ratio (i think this thing is supposed to let you know it but im not 100% sure )
Old May 17, 2005 | 09:17 PM
Seven53's Avatar
Default Re: apexi S-AFC II
I've got the directions for the new RSM-GP, however, I can't find a pinout for the ecu to wire it in. I can e-mail you whatever directions you need if you can tell me how you wired yours up.
Old May 17, 2005 | 11:56 PM
uncompiled's Avatar
No, it's not a Honda specific application. An S-AFCII is an air flow controller that lets you lie to your ECU. While it is possible to gain 10hp by properly tuning your air/fuel ratio, you should also consider future modifications before spending $300 on this. If you know you're going to turbocharge your car, you'll probably going to want to be able to adjust the timing and you'll need something more powerful. I sold my old one for $200, so if you look around online, you can probably find one around that price range.
Old May 18, 2005 | 12:04 AM
Gmoney's Avatar
Seven City Scions
would it be pointless to get one if your going to supercharger the car?
Old May 18, 2005 | 01:39 PM
05-RS1's Avatar
^maybe. depends if the s/c comes with a ECU reflash or not. if it does, u gota take the safc-2 off. if no, then u can dyno tune with the s/c and gain more power with better gas mpg.
so the safc-2 DOES work for the tC? if it does, i'm gona get it. before anyone tunes the thing, they should be sure they are NOT going to add anymore bolt-ons b/c it would mess up the a/f settings u have already tuned for. so be sure u have the big 3, i/rh/s-pipe/e, then tune it and u'l be set. u have to take ur car to a dyno w/ a/f readout and the professional there will tune it for u.
safc-2 however cannot tune cam angles or advance timing.
Old May 18, 2005 | 11:33 PM
insanetc's Avatar
if you pm this kid joe@dezod he has one in his tc and im sure he wouldnt mind helping you oout with any questions....and i ordered one for my tc aswell....
Old May 19, 2005 | 01:11 AM
i thought he had an rsm
Old May 19, 2005 | 03:18 PM
insanetc's Avatar
i thought he had an afc but maybe he has a rsm...but pretty sure its a afc...
Old May 19, 2005 | 04:34 PM
yeah he has an rsm he used it to do a nice little suspension test https://www.scionlife.com/forums/vie...028&highlight=
Old May 19, 2005 | 06:22 PM
-Keith-'s Avatar
EVERYONE...
S-AFC-II should not be used to fully tune your car... It only adjust every 600 rpms... so in between that you can be going lean... This is for the added fuel for cars that have reprogramed ecus or standalones that just to on the spot adding of fuel, for test purpose... That or to look cool in the show... I had one on my xB... theres no instructions in it yet for tC so if you do it your doing it on the fly
Old May 19, 2005 | 06:28 PM
the new s-afc-II does it in 200 rpm incremints doesnt it?
Old May 19, 2005 | 07:31 PM
-Keith-'s Avatar
the black on black... is 600 it use to be 500
Old May 19, 2005 | 09:37 PM
TheBlade's Avatar
I put an SAFC (blue screen), AVC-R, and TurboTimer on my Escort. Took me about 3 days to figure out how to make it wire up but wasnt hard. I ended up just adding a 2BAR MAP sensor off of an 88' Turbo Sunbird and spoofed the throttle position signal to the AFC (and AVC-R)
Old May 20, 2005 | 01:40 PM
05-RS1's Avatar
safc-2 is increments of 200rpm. the old safc is 500rpm.
