Automatic Transmission Upgrade Info - ZPI SOLUTION
Old Nov 7, 2005 | 12:03 PM
  #41
BrEaK_AwaY's Avatar
very intresting topic
Old Nov 9, 2005 | 08:46 AM
  #42
bubblemyster's Avatar
bump. whats the status sciondad.
Old Nov 9, 2005 | 09:19 AM
  #43
tracekillz's Avatar
i e-mailed. let me know wsup...hopefully we can get a 3rd scion maybe? yes? okay i tried. haha..
Old Nov 9, 2005 | 01:17 PM
  #44
ScionDad's Avatar
Well, I got the ESK yesterday in the mail...but I have to send it back. This will be a piece of cake to wire up guys.
There are 6 wires. A ground and 12v, Then there are 4 wires "2 each red/back and 2 each yellow/black." Basically you will cut 2 wires that go to your transmission from the ECU and place this inline with that (2 wires in from tranny and 2 wires out to ECU). It is specific which 2 wires are in(from ECU) and out (to tranny) and two wires are labeled...except the test unit they sent which was missing one label and I wasn't going to guess. Hopefully have another unit by end of week to install and test.
Basically, what Sam told me is the unit will increase the speed in which your transmission shifts....no more gliding from gear to gear.
The box is small - about 5 inches long by 3 inches wide and mounts right by the ECU.
Old Nov 9, 2005 | 01:26 PM
  #45
mattssi's Avatar
They weren't color coded at all? I could have sworn on mine it was colored so you could call em up and just get clarification.
Sounds like you got one of the first ones they made. They used to, at least, have different version like I mentioned that monitored tps, load, etc so you didn't have the firmer shifting when you didn't really need it.
Oh well, good luck and keep us posted.
Old Nov 9, 2005 | 01:50 PM
  #46
ScionDad's Avatar
Oh, they were color coded...but 2 wires were red/black and 2 wires were yellow/black.
Old Nov 9, 2005 | 01:54 PM
  #47
mattssi's Avatar
haha, so what's the problem? ;)
Old Nov 9, 2005 | 03:03 PM
  #48
David616's Avatar
ScionDad,
Are you going to post up pics while doing the install?
-David
Old Nov 9, 2005 | 03:20 PM
  #49
mattssi's Avatar
I gotta find mine, I had some good ecu pictures. I used little connectors on the 2 trans wires so when I sold the thing, I could just plug em back in. Short ecu wires are a PITA.
Old Nov 9, 2005 | 05:24 PM
  #50
krdshrk's Avatar
Let me know... I'm very interested in doing this... and also seeing how it affects your gas mileage...
Old Nov 9, 2005 | 05:30 PM
  #51
ScionDad's Avatar
Oh yea, I'll do pics and a how to and how it performs. That's also a great idea mattssi. I've been thinking how to make this connection clean, reliable and reversable.
Old Nov 9, 2005 | 05:40 PM
  #52
mattssi's Avatar
gas mileage? Doesn't at all. It indirectly may make you get on it the gas pedal more though.
Old Nov 9, 2005 | 06:11 PM
  #53
Sciondad,
why are you send it back.?
Old Nov 9, 2005 | 06:18 PM
  #54
mattssi's Avatar
Don't know which wire is what
Old Nov 9, 2005 | 06:24 PM
  #55
krdshrk's Avatar
Well, will this ECU cause it to upshift like it always does or not?
Old Nov 9, 2005 | 06:32 PM
  #56
mattssi's Avatar
it effects the line pressure during shifts. It doesnt' change shift points or do anything like that. You just get a firmer shift.
Old Nov 9, 2005 | 06:36 PM
  #57
krdshrk's Avatar
Aha... ok then. In that case i'm REALLY interested now :D
Old Nov 10, 2005 | 01:16 AM
  #58
miamibusta69's Avatar
Ok so where do i buy this damn thing? If the box sits next to your ecu.. How do you turn this thing off to go back to normal crappy auto mode like you said it would?
Old Nov 10, 2005 | 01:45 AM
  #59
mattssi's Avatar
Does anyone read all the posts?
They HAD different versions. Mine, for instance had a green switch. Others had no switch, and yet gen3 had a bunch of other features (tps, load, etc)
Old Nov 10, 2005 | 04:22 AM
  #60
David616's Avatar
I am ready to order mine
