Automatic Transmission Upgrade Info - ZPI SOLUTION
Originally Posted by mattssi
Does anyone read all the posts?
They HAD different versions. Mine, for instance had a green switch. Others had no switch, and yet gen3 had a bunch of other features (tps, load, etc)
Originally Posted by miamibusta69
SO whos selling it?
I sent mine back and waiting for another. So, hopefully one of us will get it tested really soon.
and probably turboeast.com directly
ZPI I presume is going to offer the E.S.K with the turbos and Superchargers for the automatics that order.
I wouldn't. The variables in the ECU program are probably different.
Yeah...
Similary to like programming an emanage for one car and slapping it on a nother without retuning
maybe a little off-topic, what are the odds that the "variables" would be the same for the 4-speed auto transmission in the gen5 2az-fe camry (E-150)? the camry has a different final drive (correct me if im wrong), but other than that, are they basically the same transmission? so would the variables be the same? or would there be different variables catering to the taller (or shorter?) final drive?
when will it be available from zpi ? can it be turned off ad on via button?
would like the option to hit have 3 buttons.
1) Disable and run stock
2) Enable - improved shift
3) (flip red cover and hit switch) Slam thru the gears at track
All this sounds good, but wouldn't it also be possible to "flash" a different program into the trans computer?
I was wondering about this today after I came over a fast hill, off throttle, and had to hit the brakes a little harder than normal for the next curve...I thought the back-end was gonna come around when it downshifted...WHOA!!
This makes me want to change the way that whole thing works...and if it helps out my milage, I'm all for that!!
Dont' get me wrong, though...I LIKE the idea of 3 buttons, fer shure...(Where would YOU mount it??)
Originally Posted by AZURETCTONY
Nobody out there with Scion TC has swapped their trans. fluid or cares to help me out? Step-by-step ? Fill Plug locations ? Anything...
