Autometer Narrowband to Wideband Converter - Interesting
Originally Posted by matty-tC
Originally Posted by lo_bux_racer
Corky's book won't tell you the things you need to know about the original design, but you are right, if you want to turbo anything, it's a great tome. And when I said car, I meant the whole car, not just the engine. There are sections on the engine design, chassis design, body design, and "body electrical" covering all the ancillary systems. It's amazing what you can learn about the car from the factory documentation.
p.s. i like women
Originally Posted by ScionDad
Originally Posted by mattssi
but how do you use that gauge if the voltage output is still not 0-5v?
I'm wondering if I could use the wideband 02 sensor sent with the M-300 Bosch controller and remove the stock one.
THe reason I say this is the car had 4 02 sensors originally, 2 were removed w/ the turbo kit install, and one went bad. All the wiring was done in the ecu to read the one o2 sensor to keep the cel off. As long as it worked and the heater circuit worked, my cel was off. So in retrospect, I could have made the wiring changes at the beginning and replaced the 1 bad o2 sensore w/ the wideband one. sweeet
mischman
Sep 15, 2015 03:38 PM
