bad gas mileage with alphawerks header..
Old May 1, 2006 | 06:13 PM
vvti24's Avatar
Default bad gas mileage with alphawerks header..
I traveled 60miles half city and half highway and used a little over a quarter tank of gas.. i only redlined it once after a toll... I cruised around 70-80mph.. am i running rich with this new header? cuz i feel like my gas mileage has gone down...
Old May 1, 2006 | 06:41 PM
pyxy_567's Avatar
reset your ECU by disconnecting your battery terminal.......
Old May 1, 2006 | 07:04 PM
The_Instigator's Avatar
have you documented your mileage to see what you are actually getting?
Old May 1, 2006 | 07:13 PM
mattvs's Avatar
You'll not use so much gas if you keep your rpms down :o
Cruising at 80mph is not the way. Keep it to 65/70 and you'll see an increase. City driving with stoplights and traffic isn't good either. It's not your header, it's your driving habits.
Old May 1, 2006 | 10:45 PM
vvti24's Avatar
my driving habit would be shifting 2500rpms regularly or redlining like crazy.. overall, i guess i'll just reset the ecu, but i hope my CEL won't go on... i've been over 2000miles CEL free
Old May 2, 2006 | 09:55 PM
etsnet's Avatar
It'll go on, I went 200miles before it came on. I'm surpised it didn't come on yet. Did you damage the O2 sensor when installing? If you didn't reset the ECU after install that could be the reason.
Old May 2, 2006 | 11:54 PM
vvti24's Avatar
no i didnt damage the 02 sensor.. i just gota stop redlining...
Old May 3, 2006 | 12:01 AM
p2filz's Avatar
check and make sure the headers are tight enough... if there isnt an airtight seal, it may mess with the O2 guage.
Old May 3, 2006 | 01:02 AM
05TXFM's Avatar
So your gas mileage should not change when you put on headers?
Old May 3, 2006 | 05:35 AM
reagulator's Avatar
it should get slightly better because its better flowing. my mpg got better. ive seen 33 mpg on some trips
Old May 3, 2006 | 03:24 PM
Weapon-R's Avatar
most cases of running too rich is because of the O2 Sensor having incorrect readings. A cel light will not tell you that 100% of the time. But easy fix is a CEL Eliminator which will put your O2 readings back to normal.
Old May 3, 2006 | 04:54 PM
vvti24's Avatar
i heard a header can decrease gas mileage by a little bit, because of more combustion caused by a more free flowing header...
evolving_machine
Oct 21, 2023 01:16 PM
GoodVibes
21
May 22, 2020 04:27 PM
NewBox06
Feb 3, 2015 04:02 AM
Bobb_Todd
Jan 16, 2015 06:57 PM
evolving_machine
Jan 13, 2015 08:04 PM
