bolt on power
right now i have
mmw header
fujita CAI
agency light weight pully
what else could i do for some more power
i cant really think of anything
and no FI or motor work
is there anything because im drawing a blank
mmw header
fujita CAI
Originally Posted by Sleep3r
yes full exhaust and get a stiffy! it helps alot no hp gains but more power to the ground / eliminating wheel hop
Originally Posted by burninskulls0911
how lond does it take to take out the motor mounts and put new ones in on the tc?
well right now i have a resonator that is hitting the frame pretty bad and it shakes so bad so im going to fix that and im going to make some motor mounts and see what happens
Here's a good way to get power. Your I/H/E set up, fuel pressure regulator, fuel pump, injectors, 50 shot of nitrous, a good clutch, lsd and a short shifter with some sticky tires and you'll have a good 13 sec car! Technically this is all pretty simple bolt ons. Not too hard! Just my opinion though.
Doubt he would be 13 sec car without some engine work. Fuel injectors and pump will also be negligible unless significant engine work is done. Unless you are getting more air in there you will not be making any more power.
Originally Posted by Akya
dude you want something to add power check out the aquatune its hydrogen injection for your car its supposed to give some mad power. i want one too bad i cant afford it yet.
