Car clicks but won’t Start. I need Help..
Old Mar 9, 2021 | 08:48 PM
Dannyhight's Avatar
Default Car clicks but won’t Start. I need Help..
So I just got finish replacing the engine in my 07 Scion tC and whenever I try and crank it, it makes the ticking sound but doesn’t start. But when I put the negative jumper cable on a starter bolt it starts right up. I checked my battery with the voltmeter and it’s fine. Only thing I can think of is
the negative cable is messed up somehow? Or I did forget to put the ground wire that’s attached to the wiring harness on. The one that’s in between the intake. Will that stop it from starting because I really don’t want to have to take the intake off after I just put the engine in and everything together.
Old Mar 9, 2021 | 08:53 PM
drizzoh's Avatar
Does your volt meter measure CCA's? If it's clicking it's getting power to the starter, just not enough to use it. I'd try a fresh battery.
Old Mar 9, 2021 | 10:50 PM
DannoXYZ's Avatar
Moderator
Moderator
Wiring is wrong somehow. Applying negative ground-cable to starter anywhere should not cause it to run.
1. Starter is grounded by case bolted to engine/bellhousing. Adding additional ground cable does nothing.
2. There should be ground cable directly from battery -ground terminal directly to body of car. Is it attached?
3. Starter is activated by starter-solenoid transferring +12v from battery +positive terminal to starter's +12v terminal.
Use multimeter to measure following points:
1. voltage at battery's +12v terminal. Volts = ???
2. follow cable from +12v terminal of battery to starter-solenoid's input +12v terminal. Measure voltage at starter-solenoid's +12v terminal. Volts = ???
3. when cranking, measure voltage at starter-solenoid's output +12v terminal. Volts = ???
RRamza
Sep 24, 2022 06:25 PM
Jordly221
Feb 13, 2019 05:29 PM
victor123897
Apr 20, 2013 10:36 PM
rvitito
Sep 16, 2010 02:46 AM
SickleCell
Regional - Southeast
31
Apr 3, 2007 03:12 PM
