TC Won't Start
Old Apr 17, 2013 | 10:16 PM
victor123897's Avatar
Thumbs down TC Won't Start
So my previous engine blew, long story short, i replaced it, as well as my wiring harness. I got everything wired and hooked up.
Go to crank the key... Nothing besides a click (Of the starter wheel being pushed out) And an electrical hum from Satan himself.
The Starter is receiving power, i checked it with a volt meter. I wired the stater directly to the battery and still nothing. It simply pushed out the starter wheel...
Fixes Ive Tried
-Charged battery at O'Reillies (Battery is 3 months old)
-Wired up starter directly
-Checked all fuses
-Re-Ground the wire
-Got starter checked at O'Reillies (All came out good)
-Bought a new starter
Im seriously so frustrated. It's bad enough swapping an engine, but after that having the car not even crank at all... That is just the worst. The radio and sub-woofers still play when they is is in the accessory position. When i turn it to the on to crank it, it just makes a loud click and then an electrical hum.
Please Help any tips and advice is appreciated.
Old Apr 18, 2013 | 03:29 AM
cmcpride's Avatar
well, have you tried cranking the engine by hand? you could use a 10mm socket and use it on the alternator and crank it ,, its possible your new or used engine is seized. check to see if your power is connected from starter to positive battery, also check your ground..
Old Apr 18, 2013 | 03:34 AM
cmcpride's Avatar
and when i say check your power to starter i mean the main battery terminal not the small ignition cable with connecter , i had a friend who connected his main starter cable to ground thinking it was a ground wire....
Old Apr 18, 2013 | 03:36 AM
Smile
Exactly what i did. I connected that thinking it was a ground... Butttt ya live and ya learn. Got it all fixed up Thanks for your help!
Old Apr 20, 2013 | 10:36 PM
cmcpride's Avatar
no problem,, glad its back on the road
Jordly221
Feb 13, 2019 05:29 PM
Mhawkins65
Mar 18, 2015 03:16 AM
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
scionspecialistvegas
Dec 15, 2003 11:21 AM
