CEL light and engine is running rich.
Old Oct 21, 2007 | 10:21 PM
REVOSOLDIER's Avatar
Default CEL light and engine is running rich.
installed number 1 headers also have number one catback exhaust. the exhaust has no cat and obviously neither does the header. i was reading that the antifouler doesnt really workand i have no cat to relocate the o2 bung behind. so i dont know what to do...ik the car is running rich because you can smell it when you get behind the car....and ive had like 8 people smell it and they all agree. ne helpful tips?
Old Oct 22, 2007 | 07:00 AM
sp0t's Avatar
it smells because you simply have no cat.
the antifouler trick works. try it out. i've had my antifoulers on there for a good year already.
Old Oct 22, 2007 | 10:23 AM
Mid_Life_tC-risis's Avatar
X2. No cat = stink.
If you were running rich, and you're probably not, you'd throw a fault code for it. You probably have just a P0420 code now which is what the anti-fouler will (more often than not) prevent.
Old Oct 22, 2007 | 11:19 PM
cool thanks guys. gettin the antifouler asap found one for 25 bucs good deal?
Old Oct 22, 2007 | 11:59 PM
No. Spend about $3 at Autozone and do this:
https://www.scionlife.com/forums/viewtopic.php?t=56520
(scroll about 2/3 way down for anti-fouler install)
Old Oct 23, 2007 | 12:05 AM
the drill thing? with the two antifouls right? how much does the drill bit cost because i dont have one lol..ima have to see if one of my friends have one.
Old Oct 23, 2007 | 04:06 PM
Drill bit + HELP antifoulers = way <$25. :D
I actually spent $12 for an anti-fouler from autotube.net which by the photo didn't appear to be just a drilled-out HELP anti-fouler, and they advertised "100% success on Scion tC's". Turned out to be just a drilled-out HELP anti-fouler and gave me a P0420 CEL after about 30 miles. (Adding the 2nd HELP antifouler worked.)
So what do you get for the $25 anti-fouler?
Old Oct 24, 2007 | 05:25 PM
well the pic looked to be machined somehow...and it was a 90 degree angle...but ima try the cheap way first...(just checked the bank account this morning lol.
Old Oct 24, 2007 | 06:10 PM
CSOCSO's Avatar
if i get 1 or maybe 2 fouler that wont change anything else but the CEl light?? i mean.. im not gonna do nothing bad to my engine if i get 2 foulers on the second sensor?
(2 because they said 1 is not enough for the megan headers-- CEL will come back with 1 fouler)
Old Oct 24, 2007 | 07:15 PM
no if u read more into it on the forums basically they say get two foulers...drill a 1/2 inch hole in the first one then screw the second one into the first...then screw it all into the o2 bung. sounds simple to me https://www.scionlife.com/forums/viewtopic.php?t=101069
Old Oct 24, 2007 | 08:02 PM
toeveryhour's Avatar
I gotta do this soon too... lol
Old Oct 26, 2007 | 05:25 PM
wow that was so easy to do. i bought the 42002 spark plug antifouls...drilled the 1/2 inch hole and to be honest it wasnt even that straight....still tightened right up and now no cel light good fix
daniinpitt
Apr 4, 2015 08:07 PM
greytc
Jan 12, 2015 09:49 PM
AdmirN
Jan 5, 2015 10:19 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
