Clutch problem
OK so when i am driving around my clutch pedal get stuck down my clutch still engages and disengage when this happens and the pedal is not stuck on the floor about 2 inches above. I can still press down and disengage the clutch and shift into gears. To get it back to norma i just pull the pedal back up to normal position. This does not always happen just every once in a while so i was wondering what the problem could be.
Thank u all for the responses recently my pedal has gotten worse now when i can barely depress the pedal and it will slowly go all the way to the floor and become stuck. This happens mostly when i start the car and have to hold the clutch in for a sec or two. i have checked for leaks but found none please let me know if u still think it is the clutch master cylinder.
Its definitely a hydraulic issue. Check your Slave cylinder lines and make sure it does not have a hole in it also check both your clutch master cylinder and clutch slave cylinder make sure neither of them have went bad.
