Cold Air Intake CAI Panel??? Would You Recommend Buying One
Old Feb 12, 2009 | 12:45 AM
MillerRS1's Avatar
Default Cold Air Intake CAI Panel??? Would You Recommend Buying One
Okey I just got a TRD CAI and now I am wondering if I should buy the Intake Panel From Doctor Isotope?
Does this help at all I mean its 20 bucks but im just curious if anyone has one or wud recommend it.
Any Information is helpful.
It States:
If you've got a CAI, there's a good chance you've had the upper bracket break on you. Well, instead of letting the lip on the inner fender wear a hole in your CAI piping, you should definitely consider a CAI panel. This panel mounts to the inner fender, just behind the underhood fusebox, and provides an insulated pass-thru for the CAI tubing, eliminating any chance of the piping rubbing (or rattling) against the chassis. This panel fits the AEM and TRD Cold Air Intakes.
Old Feb 12, 2009 | 12:50 AM
ack154's Avatar
MANY people on here have it. And I'll say that it's best to get it early while you have the CAI... before your lower bracket breaks on it. It will help after it breaks, but if it is still intact, this should keep it that way.
And like you said, it's just $20.
Old Feb 12, 2009 | 12:56 AM
MillerRS1's Avatar
awesome thankyou very much all i needed to know i was just a bit confused on what it did but i understand i havent installed my cai yet so ill order on tomorrow thanks again
Old Feb 12, 2009 | 01:06 AM
Mouse's Avatar
That's interesting.... is this a design issue for the TRD CAI's? I've had the Injen Techology CAI on 2 tC's and never had a rubbing issue. But for a buck I got a foot of black rubber molding and just ran it around the entire opening. looks great and got it from my Scion dealer for like a buck.
Old Feb 12, 2009 | 01:08 AM
MillerRS1's Avatar
I'm not sure but they offer it for the Injen too
Old Feb 12, 2009 | 01:09 AM
Mouse's Avatar
well for a dollar or two at your local dealer or autoparts store, just get a foot of 1/2 inch black rubber molding. and it looks nice and works just fine against occasional vibration movement while driving
Looks good, works good..and will save you 19 bucks...that you can put towards your next mod :D
Old Feb 12, 2009 | 01:37 AM
ack154's Avatar
The bracket thing is for all of them. The point at which it mounts to the engine bay (almost right under the MAF) has a crappy bracket that can't take the torque and engine movement with a CAI attached to it.
Old Feb 12, 2009 | 02:10 AM
justin6969's Avatar
were is the link so i can buy one of these!
Old Feb 12, 2009 | 02:14 AM
ack154's Avatar
http://www.doctorisotope.com/plates_and_panels
Old Feb 12, 2009 | 02:18 AM
peterng026's Avatar
i didnt like the CAI plate thing, still rattles and super annoying so I just went back to the short ram..
Old Feb 12, 2009 | 10:36 AM
justin6969's Avatar
just ordered one we'll see how it works
Old Feb 12, 2009 | 11:05 AM
MillerRS1's Avatar
If you get that and install it can you tell me how u like it thanks.
Old Feb 12, 2009 | 08:36 PM
PBCsolutions's Avatar
I have the K&N intake, of course the lower bracket broke, but the Doc I baffle did the trick for me. No more rattling or rubbing.
Old Feb 13, 2009 | 02:29 AM
justin6969's Avatar
i got the fujita CAI my thing hasint broken yet but im gettin this bcuz i think it makes it look 100% cleaner and also b4 my bracket brake's so we will see when i get it and mayb post up some pic's
Old Feb 14, 2009 | 06:44 PM
CSOCSO's Avatar
i had one from dr. iso.. i didnt like it.
the fitment was crappy... the pipe was rubbing with the plate it was making lots of noise... i had my upper bracket broke.. i had no lower bracket.... i ordered lower bracket from k&n.. it was free.. and fixed the upper bracket.. no need for the plate. And the piping was sitting really awkward with the plate. so i really hated the plate.
YES and i ordered the k&n plate!
Old Feb 14, 2009 | 08:44 PM
Trivecta's Avatar
Yea I never got mine to fit...even after taking off my CAI, but it looks cleaner with it on. My panel is just sitting in my garage...
Old Feb 14, 2009 | 08:56 PM
daffy12's Avatar
its a litte hard to angle it and make it fit in with the cai. but iot looks a lot nicer. and if you stick some double sided tape instead of the bolt it came with it get rids of the rattle...real cheap investment
CSOCSO's Avatar
yep.. to install it.. you have to take off the wheel... take off the fender liner.. take off the lower bracket, take apart the piping.. slide the lower pipe out, secure the panel.. slide the pipe back in.. etc.
its not a big deal.. you can do it in 20 mins...
the biggest problem is the awkward sitting of the pipings.. the rubbing/noise....
(or you just take the battery out the whole fuse box out and you can slide it on the cai without taking it apart :D)
Old Feb 15, 2009 | 12:20 AM
MillerRS1's Avatar
o nice thats good to know
hampton1100
May 28, 2015 07:32 AM
AxRxP
Jan 25, 2015 08:40 PM
IGotThatOrangeToaster
Jan 19, 2015 02:35 AM
cacafria97
Dec 20, 2014 08:58 PM
2fixA
Sep 25, 2003 08:06 PM
