dissappointed
So young and so unhappy - and quit bashing Geo's - I put my brother back into the passenger seat in first gear when he reached for the dash in my old Geo - should have seen the expession on his face . . . priceless. Torque at the crank is increased at the tires with gearing so if you get the gearing set it can make a difference but it helps to have more HP and less weight plus the traction to grip the road.
Originally Posted by 3min3m2
he did kinda say his car was slow compared t otheres
anyways, if you wanna compare to those guys, strap a turbo on that tC....you'll smoke em if you build the block/boost a little
And no, you won't "smoke em" if you "strap a turbo on that tC". That's almost completely false. The m5 has a 500hp v-10. I've seen them run in the mid 12's. You don't stand a chance, even with your almighty turbo.
It would take a whole hell of a lot more work than just "strapping" a turbo on. And you'll have to do more than build the "block/boost" a LITTLE.
Originally Posted by citizen01
tC is useless before 3k rpm... IMO
http://fullavit.com/content/Pictures...ncorrected.jpg
I make 145wtq @ ~2500 rpm. 153wtq @ peak. I think the low end on the tC is just fine.
Originally Posted by bcnu_702
I wouldn't say that the tC has poor low end torque. It has a 2.4 liter engine which is pretty decent for a car in this class and produces more low end torque than a honda for example. Sure, its greatest power is a higher, but the low end torque for the tC really isn't that bad. Like I said though, an intake will hurt it for a minor increase at the extreme high range rpms
Originally Posted by Mid_Life_tC-risis
Did you notice the loss in low end tq right after you put on your HKS exhaust?
most (if not all) of the headers for the tc will also have the same effect.
Originally Posted by Jiggaman
Originally Posted by rrimportracer
im dissapointed in my car right now to,
past couple of nights ive been going out with friends and their cars, sunday night was 2006 M5, last night was a 2006 E55 AMG, god those things are fast, then i got in my car, and was like crap this thing is slow
e55 = so sexxxy
don't be silly now. F22>2az in every aspect
The straight-through aftermarket mufflers flow great on the bench but appear as a pressure wave restriction at low rpm. This is why I asked the OP about his exhaust. I would be curious if he installed the HKS - which I assume has a straight-through muffler - separate from his other mods, and if so is that when he noticed the loss in low end torque.
^^Yes - of course the problem is nobody makes a well-tuned exhaust for our car. Most of the aftermarket exhausts are sold for looks and sound, as are intakes. Nobody makes a TUNED I/H/E SYSTEM for our car. Everyone staying NA has to mix and match parts and cross their fingers that they will get some decent high-end gains without sacrificing the low end. Of course the end-all answer is go turbo, but not everybody has that option.
My co-worker has a tuned I/H/E system for his Miata made by Jackson Racing. Oscar Jackson designed, then continually updated, his components until he had made power across the band with a smooth torque curve.
Hopefully somebody will do the same for the tC.
I'm just really blown away from that statement...
PHEW I'm glad someone else finally explained the IHE tuning - thanks Mid-Life. Exhost pulses and pipes interact like crazy and even a step in the diameter larger can have an effect on the exhost system. You have to take into account the engine displacement and the pipe volume which is affected by the diameter and the length of the pipe then you have to tune it for what RPM you are interested in. Even the header length before the union is critical as are the bends and the cooling all affect the header action.
^^Yes IHE design is a complicated science, and usually it's only appreciated as such in the racing community. Now, since the tC seems to be showing up more and more in racing circles, maybe a tuner outfit will design and market a good IHE setup for us - er, for the tC - just noticed you drive a box.
Yeah I'm into getting higher gas mileage not more power but part of the MPG increase involves getting more of the engine power to the wheels through friction reduction and better fuel combuston. Right now I am about 40% over EPA ratings (40mpg average) with some good days that get almost 100% over (50mpg). I did some drive train work on my R100S BMW and even after leaning out the main needle jet it still gets to redline in top gear pretty quick.
