View Poll Results: What engine do you want Scion to use?
NZ-FE same engine as xA and xB?
0%
Voters: 9. You may not vote on this poll
Which engine?
I just looked up the engines that could be used for the new coupe - stats as listed.
Rav4{Tacoma engine with the VVT-i?}
2.4-liter DOHC 16-valve EFI 4-cylinder with Variable Valve Timing with intelligence (VVT-i)
161 hp @ 5,700 rpm
165 lb.-ft. @ 4,000 rpm
Tacoma
2.4-liter DOHC EFI 4-cylinder
142 hp @ 5,000 rpm
160 lb.-ft. @ 4,000 rpm
Solara
2.4-liter DOHC
16-valve VVT-i 4-cylinder
157 hp @ 5,600 rpm
162 lb.-ft. @ 4,000 rpm
ZZ-FE{Corolla , MR , Matrix , Celica}
1.8-liter double overhead cam (DOHC)
16-valve 4-cylinder with Variable Valve Timing with intelligence (VVT-i)
140 hp @ 6,400 rpm
125 lb.-ft. @ 4,200 rpm
ZZ-GE{Celica GT-S and Matrix XRS}
16-valve 4-cylinder with Variable Valve Timing and Lift with intelligence (VVTL-i)
180 hp @ 7,600 rpm
130 lb.-ft. @ 6,800 rpm
NZ {Scion xA and xB , Echo}
1.5 liter (DOHC) 16-valve VVT-i 4-cylinder
108 hp @ 6,000 rpm
105 lb.-ft. @ 4,200 rpm
Please note the RPMs at which the HP and Torque are produced. The only engine on the list that is really a high performance engine is the ZZ-GE but even the ZZ-FE has more potential than any of the 2.4liter engines and with a turbo the NZ can match the 2.4 liters{and that is with like 4lbs of boost}. Now which engine do you want? Do you want a low rev moderate power engine that is very smooth? or Do you want a high rev engine with good power and potential for more? Although there is a bit loss to fuel economy with the higher performance engines , it really is a small difference{a few miles per gallon}. I have also listed a poll - let us hope Scion actually sees it.
161 hp @ 5,700 rpm
Tacoma
142 hp @ 5,000 rpm
Solara
2.4-liter DOHC
157 hp @ 5,600 rpm
140 hp @ 6,400 rpm
180 hp @ 7,600 rpm
108 hp @ 6,000 rpm
I just found out that Toyota Europe is working on a new 2.4 liter engine for the Avensis. Perhaps this is the engine that the coupe will have? However it is not much better in performance than the 2.4 out of the Camry/Solara but does get better gas miliage.
sIcKsCiOnS
I'd like to see the GT-S engine used. But the Corolla engine might work. What do you guys think?
Maybe not a performer in the Camry/Solara, but what about a smaller coupe tuned for performance? Please if they use the Corolla engine, they now have that super charger ;).
Originally Posted by vpkb
3SGTE would be awsome
jctc06
Apr 16, 2015 12:11 AM
carid
Mar 30, 2015 07:08 AM
