engine bearing (problem) sound?
Old Jun 9, 2006 | 12:51 PM
engifineer's Avatar
That is not an engine problem. Most likely something stuck in your tire. That is the first simple thing to check. An internal bearing issue will not increase frequency with wheel speed. It does so with engine speed, whether or not the car is moving or not.
Old Jun 9, 2006 | 04:43 PM
dp-_-'s Avatar
the sound is wierd....sometimes it's really loud, other times barely audible. We've checked all 4 tires and there's nothing rubbing & I've had this problem before after my SS+P install and it happened to be one of the lines tapping on the heatshield on the brakes.
We've also tried looking for rocks behind the heatshield, bending it back anyway, re-arranging the abs lines and stuff....still clicks. I'm headed over to a shop right now, I'll post if I find a solution.
Old Jun 9, 2006 | 06:04 PM
engifineer's Avatar
I had a mustang that began making a kind of ticking sound that came from one of the wheels or something in that area. It was more of a mix between a tick and a squish... but after doing it for 10k miles I gave up looking for it and wrote it off to a wierd tire issue
Old Jun 10, 2006 | 03:06 AM
jwaggz82's Avatar
i was just going to say look at the tire. i had a truck before this w/ large tires and this was a weekly problem for me (so i was deff used to taking my key and poping them out ...just make sure w/ the plastic keys we have that u dont break it).
Old Jun 11, 2006 | 02:38 PM
scion8183's Avatar
does this sound like an engine bearing noise? Has anyone had an issue with a clicking noise coming from under there car when shifting? It only does it when I shift from 1-2-3 there is no noise with 4-5. But when ever i let off of the clutch in 1-2-3 there is a loud click sound, is this common? It doesn't matter is the car has been running for 5 min or 4 hours it still makes the noise, it just gets louder the longer i run my car for!!
Old Jun 29, 2006 | 09:51 PM
jwaggz82's Avatar
does anybody know that post where that guy had the bearning blown video?
Old Jun 29, 2006 | 10:18 PM
dp-_-'s Avatar
i think you're thinking about the guy that posted a video about the AP pulley....
Old Jun 29, 2006 | 10:22 PM
jwaggz82's Avatar
i dunno - all i know is that he had a video and it showed what bad bearings sounded like.
Old Jun 29, 2006 | 10:26 PM
dp-_-'s Avatar
there's only one guy (i believe) that had that issue....
im thinking stu_gotti, but i'm not sure.
If the person only took a look at the thread....
Old Jun 29, 2006 | 10:29 PM
jwaggz82's Avatar
I think it was an actual supercharger bearing issue ....
Old Jun 30, 2006 | 03:23 AM
insanetc's Avatar
Originally Posted by KurtRS1
I have a whining noise that happens when I drive. Is that what it might be? Also what causes this problem? I noticed it a month after I got my ZPI V2 crank pulley.
bro my car sound slike that sometimes..it did it alot in the winter..i ahev a full n/a set up but the nst pulley is on its way but i stillahve that sound..i brought it to the dealer an dhe heard it he said most toyota motors sound like that..he said it will be fine and that wa sthe shop manager..so if something does go wrong ythen i will be peed off kid..lol..but that waa like 4-5 months ago so nothing has happend yet and i do alot of street racin and stuff....
Old Jun 30, 2006 | 07:30 AM
JimmyScion's Avatar
mine has that noise also i didnt know where it came from, so yesterday im parking in front of my house and i heard it againg it comes and goes, so i opened the hood while it was doing it, and the sound came out the tranny i thinks its the bearing of the clutch (maybe that is whats happening to you)going on monday to the dealer to check it. YOU SHOULD ALSO.
Old Jun 30, 2006 | 12:09 PM
insanetc's Avatar
yah i should....but for some reason..it doesnt do it as much now in the summer time...i dunno if the winter has anything to do with it but now that its warmer it hardly does it so...im still goin 2 bring it by the dealer..hopefully they dont yell at me for my n/a set-up...lol
Old Jun 30, 2006 | 08:55 PM
engifineer's Avatar
No, his number 4 rod bearing spun. About 4 have had that happened from what I have read online.
Old Jul 1, 2006 | 12:29 AM
jwaggz82's Avatar
My god - That sounded like a table saw.
Old Jul 1, 2006 | 05:29 AM
mattvs's Avatar
Curious if all of you that have this noise have swapped your crank pulley.
Old Jul 1, 2006 | 05:42 AM
jwaggz82's Avatar
i havent swapped any pulley.
Old Mar 13, 2007 | 03:20 PM
jwaggz82's Avatar
Well I have narrowed down the problem to the transmission. The noise is only when in gear.
Old May 29, 2007 | 06:20 PM
BionicJuic3's Avatar
if the knocking noise still persist what can you do abotu it?
Old May 29, 2007 | 11:50 PM
jwaggz82's Avatar
^ get your engine rebuilt
