First Oil Change!
Old Nov 17, 2006 | 02:23 AM
mike6789k's Avatar
oh, but i just checked the color of my oil, it looks like it's still right out of the bottle... lol
Old Nov 17, 2006 | 02:53 AM
Jan06xB's Avatar
Pretty sure that the tC oil is going to be the same very high quality synthetic that my xB came with from the factory. They put some very high quality oil in it . . . the dealer on the other hand may not use such a high quality oil since they don't warrenty the engine the factory does. But anyway you should have been told what the breaking in first oil change should be from the dealer - I was told 3600 miles and have heard more and less depending upon the dealer. The oil will look pretty clean on the dipstick but when you drain it out woooow it will be pretty dark. Don't change it too soon or you will not be breaking in the engine enough. Hot weather is not as bad as winter weather. The engines today in quality cars like these have very good piston seals on the rings so the oil does last a lot longer than in the older cars years ago. Going 5000 on regular is is probably ok if you are not racing it all the time but you are better off in the long run to use a good synthetic for a little better gas mileage.
Old Nov 17, 2006 | 03:03 AM
3min3m2's Avatar
i go with mobil 1, changing 5000....the only time it has looked kinda nasty was after i did some drag racing(it was legal, at the strip, no street racing), and the oil was kinda gritty after 5k(waited to 5 on the first one....never thought otherwise)
i think its ok...i run 10w or 5w 30 in my tc(dont remember,,,know it calls for 5w, dont know which it was!)
and it looks good..just use good synthetic, and a good filter, u should be ok, as long as its nothing serious....i;m gonna look at it hard this time at 5k, if its still real dark, u bet its gonna go down to 4k.....
Old Nov 17, 2006 | 03:09 AM
Tcguy85's Avatar
i changed mine for the first time at about 1700 and it still looked fine but i'd rather be safe than sorry later. i switched to full synthetic and will be changing that every 4-5k. i wouldn't go 5000 with regular oil but 5000 should be perfectly fine with a good synthetic.
Old Nov 17, 2006 | 03:10 AM
Jan06xB's Avatar
Dark is not as bad as not slippery so if it is still slippery between your fingers it still has some lubrication in it. When your fingers don't slide then you waited too long. I got tired of figuring out what to do with the waste oil so I collected it for my last car - this time I changed to Synlube for the first oil change and now I don't have to change it again for 150k or 15 years. Only a couple of filter changes at 36k and 75k -crazy huh!
Old Nov 17, 2006 | 03:49 AM
g3kko's Avatar
I agree on that "crazy" bit.
Old Nov 17, 2006 | 03:57 AM
Skatewerks6's Avatar
i got mine at 11k miles haha
Old Nov 17, 2006 | 04:50 AM
mike6789k's Avatar
Ok, i've decided to have the dealer change the oil when I hit 5000 miles, then I will change the oil 3000 miles after that, and when I hit 10000 i will go synthetic.
If you go synthetic too soon (like earlier than 10k miles... you havent broken in the engine enough and your piston rings arent fully seated...)
Old Nov 17, 2006 | 12:07 PM
Jan06xB's Avatar
Hello it comes with synthetic from the FACTORY! Didn't I just say that?
Old Nov 17, 2006 | 08:11 PM
mike6789k's Avatar
Jan06xB - WHAT?! no, you are mis informed! i think you have our cars confused with porsches
Old Nov 18, 2006 | 12:42 AM
Jan06xB's Avatar
I purchased my Synlube from an oil expert name Miro and he told me not to get the oil changed at the dealer because the oil from the factory was in fact a very high quality synthetic and it would be better to have trace amounts of that in the engine when I changed over to Synlube than what the dealer would put in the engine. What makes you think that it is regular oil?
Old Nov 18, 2006 | 02:10 AM
mike6789k's Avatar
because it IS regular oil... this isnt some high performance engine, it's a 4 cyl econobox...
Old Nov 18, 2006 | 08:16 PM
kungpaosamuraiii's Avatar
How are you so sure? Toyota does a lot of things that no one understands. One thing for sure is that they take care of their engines. I wouldn't be surprised if Toyota uses a special break-in oil. I'm not convinced they do but I wouldn't discount it immediately.
Old Nov 18, 2006 | 08:50 PM
Shogun's Avatar
New tC owners: When you get your first oil change done, send it out to get an oil analysis. I will try as well when the time comes. Maybe we will get an answer to 2 questions. With so many owners, someone must be able to do it.
zzbear
Apr 19, 2015 06:18 PM
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
