Gas Saving Tips
Originally Posted by markymarkcirca
Originally Posted by ack154
Haha... the 05 tC reports are about 99.9% mine. There were like 5 on there before I started. The rest are mine. I'm not very frugal many times with my gas. Plus that includes multiple autox events each summer. There are a few road trips on there of 30mpg or better.
My tC, at its worst, has gotten as low as 16.5 - 18 mpgs. I then started driving much more cautiously, and now I'm consistently getting 22-23 mpgs. Granted, I'd say about 80% of my driving is city. Only things done to the car are Injen intake and Injen exhaust. I do like to go quick on the thruway from time to time, but for the most part not past 80 or 85
Right now I'm driving an 07 G6 GT and it has a mileage indicator, I really find that useful and wish the tc had that too
Gas prices suck but I can't find myself cruising along with gramps in his buick
Originally Posted by CarbonXe
^ Yes there is, it's called look at the receipt and see exactly how much fuel went into the car. Then keep track of how much gas was used and how many miles were driven.
But yes sorry trrocks, should have read your first post more carefully,
here's the link
Yea, same thing, I thought you were trying to calculate strictly off the needle.
If you really want to improve it, turn the car off at stop lights. It's a proven fact that cars now use substantially less fuel to start than to idle.
i get about 27, and i do top off...
but i drive it like i stole it, and still get good MPG..
highest was 33, lowest was 23..
not much more here to say on gas saving tips unless you get into improving engine efficiency with exhaust, etc.
im getting on average about 23mpg.. i think alot of the reason is that my car doesnt warm up untill im a mile from work. I do alot of really short trips and no highway driving at all
I guess in a sence i use less gas per day so i cant complain that my milage isnt higher
The best solution IMO would be - if it were possible with this car - an ECU reflash, which is an option for Hondas, Nissans, and others, but not Scion. You could tune for either maximum HP gains or best fuel efficiency ... heck you could tune for best mpg below 3000 rpm AND max power above it, any way you want it, and would benefit whether you're just modded with bolt-ons or boosted. And could be reflashed back to stock if needed.
Won't happen though until someone hacks the ECU ...
My question is,
Has anyone added anything to their car, and seen a bump in overall MPG? Of course, I hope you are recording your data regularly so its not just variable data. I have considered adding the TRD air filter. Has anyone seen any performance increase because of this?
No, "performance" drop-in filters are a waste of money ... won't give you any more HP or better mileage.
Like you I carefully document my mpg's at every fill-up. I've added a cold air intake, header, and exhaust and overall mileage hasn't changed for better or worse ... still comes down to how hard I drive and how often the highway becomes a crawl.
Honestly by buying a 4-cylinder fwd sub-compact and driving conservatively you've done about the best you can do to wring fuel economy out of an automobile ... even hybrids have been shown not to be a bargain unless you drive only in city traffic.
If you're still determined to improve mpg's you're pretty much limited to fringe methods like hypermiling (which is dangerous), adding wierd chemicals to your gas, and home-brewed hydrogen systems ... a friend just got the plans to build an on-board hydrogen system (justaddwater.com is the web site iirc) ... he's going to put it on his old Chevy van and see what happens ... supposed to increase your mileage up to 70% ... idk
Friction is the biggest enemy when it comes to gas efficiency. So with that in mind keeping the internal lubed up with quality oil is a start. Use synthetic oils for your engine and transmission will yield results. Lighten up the load on your car. It'll take less energy to get the car moving up hills or from a start. Lighten up rotating mass is even better. The theory is for every 1lbs of rotating mass, frees up 2hp for your car.
To help the pistons rotate more efficiently (for example pushing the exhaust out of the combustion chamber) a quality header and exhaust would aid in the flow of extracting fumes from the car. Also just like you and me the harder we run the more air we need to perform. Such is the same with your car. Inflated your tires a little higher than 35psi to help reduce rolling fiction. All this will help save mpg and I'm sure there are even more ways like an ECU reflash but it won't come easy and I'm glad this tread was posted to bounce ideas off each other.
Good Posts Everyone.
I think everyone should try and keep track of their gas mileage for a starter. If you start doing that you will see trends that you normally wouldn't see. If you want me to data crunch, just let me know ; )
I have started keeping tabs of time of day the gas is pumped. I haven't seen any trends thus far, but I will let you know if any show up.
I have seen a major seasonal trend. Where is everyone located? Can you post your location and the average temperature for the 4 seasons? Then post your MPG per season and maybe we can get a brief idea if temperature has a major effect or not.
i dont think its temp as much as it is road conditions.
(if you live somewhere with alot of snow and ice your tires will spin more when trying to accelerate up hills, etc...)
Originally Posted by trrocks03
I live in texas, and we don't get snow very often. But I do see a difference in MPG.
Winter 07-08 : MPG = 26.575
Summer 08: MPG = 30.525
1. Make sure your tires are FULL. I got 2-3mpg more out of my car at the tail end of my stock tires b/c I cranked the tire psi to the max rated on the sidewall. You won't believe how far you can coast with them at 50psi!!!
2. K&N filter, I say this with some reservations since I know many of you have full intakes but I have read up on how K&N goes to great lengths to make the filters as effiencient as possible WITHOUT giving the cars ECU a headache to deal with. If your wondering why it boosts MPG, it reduces the engines pumping loses of air coming in. Yes it should also boost a pony or two.
They do cost 50 bucks or so and that does buy a decent bit of fuel though.
dave
dave
