Got some more info on the Supercharger.....
To all of you that don't want to believe me, then don't bother to respond. There is no need for the negativity. For those of you who are actually interested in the information that I have.....read on.
The superchargers are on the shelves as we speak but cannot be shipped out until they get the new company to build the new ECU. Any real pertinent info on it is considered very confidential and is not even making it to the Toyota Execs but I was able to get a littlee more info.
Boost: Still not released
HP at WHEELS: 190 hp
HP w/ intercooler at wheels: 235 hp
Intercooler will be in the same place as Sparco one so it will be behind the lower honeycomb grille. And the price, though not releaased either, will keep a base model just under $20K so the S/C will be about $3500.
My guess is because most tCs are already made, which is their test cars... so they get the newly built S/C then bolt it on to an already manufactured tC, then measure the power. Seems like a lower cost and it shows how well the ECu takes to the adjustments, rather than a computer on the flywheel dyno.
I'll let someone else with a little more knowledge answer that. But at the crank it is 208 with super charger and about 255 with the intercooler if I remember right.
well Im sure that with the intercooler it allows you to run a few pounds more boost, thats where you get your hp from, without intercooler you would only probably run 4-5 pounds MAX but with intercooler, you could probably saftely boost 7-8
Not to sound like I am picking... but could you give us the source of the info? that determines a whole lot. the only believable info I have received has been from scion so far
