Grounding Point
I am fabricating a grounding kit. I need to know what grounding points other kits out there use:
Sun Hyper
APEXi
Racing Solutions
etc.
Pictures of grounding point locations is much appreciated.
Sun Hyper
APEXi
Racing Solutions
etc.
When grounding to the chassis, u might wanna use a volt meter... In most cases ur going to have to remove some paint around which ever bolt ur goin to use for grounding (this creates a true grounding point whereas the paint blocks voltage from passing properly).
shinkuu, go to the tech section like I told you earlier and use that one as a reference. Be sure you read the whole article. You can use the same points as the xb,xa, you can even pm the person who did the article and ask him. The article gives you the readings of the meter.
JOHN
JOHN
crimson_sinn
Sep 25, 2015 09:41 PM
