Has anyone changed their final drive ratio (ring/pinion)?
Old Jan 24, 2008 | 06:24 PM
garabaldy's Avatar
Default Has anyone changed their final drive ratio (ring/pinion)?
I have a 2006 TC with a Turbo putting out about 360 WHP and want to put taller gears since I have more HP and I'm almost a redline in 4th at the end of the quarter mile.
Have you done this? and if so what ratio did you use?
Old Jan 24, 2008 | 08:22 PM
bigwillystyle23's Avatar
thats a good idea. itll put a lot less stress on your drivetrain for sure. not sure what ratio to use. whats the stock ratio?
Old Jan 24, 2008 | 08:24 PM
bloody_mess's Avatar
i was lookin into that just for the hell of it without turbo
Old Jan 24, 2008 | 08:44 PM
w/out turbo youd have to downshift to pass cars on the interstate and such but you would get better highway mileage. also youd have to ride the clutch a little bit more =/ as long as you knew what you were doing and didnt ride it anymore than necessary youd probably be fine.
Old Jan 24, 2008 | 09:01 PM
NurSpec's Avatar
Transmission Five-speed manual
Gear Ratios
1: 3.538:1
2: 2.045:1
3: 1.333:1
4: 0.972:1
5: 0.0775:1
Final drive: 4.235:1
Differential: Open
Old Jan 25, 2008 | 02:59 AM
Autodromo's Avatar
Good idea, and you might also want to add install the LSD since you're taking the tranny apart.
Old Jan 25, 2008 | 03:48 AM
Keeshwah's Avatar
camry fd.
Old Jan 25, 2008 | 01:53 PM
garabaldy's Avatar
That is actually my plan , I'm going to put in a Quaife LSD and while it was apart I thought I would change the gearing
Old Jan 25, 2008 | 02:27 PM
SePaTc's Avatar
changing the final drive will affect ALL gears though, meaning it could affect some lower gears as well... just a thought to keep in mind.
if you're happy with all the other gears, you might just want to replace 4th....
though i think you are just wasting your time anyway..
Old Jan 25, 2008 | 02:46 PM
garabaldy's Avatar
I want to have all my gears changed not just 4th, but good point...
Old Jan 25, 2008 | 03:27 PM
Keeshwah's Avatar
i think its a good idea. have nice gas mileage when u want it and use ur snail power when u need it.
voodoo2crue
Mar 18, 2015 01:30 AM
mrsocks
Jan 20, 2015 01:29 PM
sensez
34
Nov 24, 2004 12:30 AM
fliggah
May 28, 2004 07:51 PM
DjFrOsT
Nov 14, 2003 05:26 AM
