Having engine delay after installing intake
Waz Crack'in people..
After installing the intake I notice sometimes when I step on the gas theres a "delay" in the engine then POW! it takes off like a bat outta hell...Then sometimes it does it normal...
I have the short ram intake setup...becuz of this is there not "enough" air getting to the air filter???
or is cuz of the "drive-by-wire" system??
Thanks!!!!!
Thanks!!!!!
the battery disconnection did nothing really, let it run a while, maybe drive it around the block, and check your owners manual because you're gonna probably have to reset the windows
Check your MAF sensor. Last time I cleaned my intake I put too much oil on the filter and it ended up getting all over my sensors and cause the same problem. Maybe your filter came pre-overoiled and youre having the same problem? Take a look at it and if it has oil clean it with some sensor spray.
hampton1100
May 28, 2015 07:32 AM
hotroddelux
Dec 3, 2014 11:33 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
eric_m
29
Oct 12, 2003 08:22 AM
