header gasket?
Old Feb 1, 2006 | 12:44 AM
Zadra's Avatar
Default header gasket?
I just ordered the MMW header, where can I find a header gasket? ZPI has OEM ones...are there any better?
Old Feb 1, 2006 | 01:13 AM
reagulator's Avatar
get it at the dealership
Old Feb 1, 2006 | 01:21 AM
WeDriveScions's Avatar
^ Yep - That's the best idea really....
Old Feb 1, 2006 | 01:44 AM
SXT_HuntToKill's Avatar
DelMarVa
should come with the header
Old Feb 1, 2006 | 03:42 AM
Zadra's Avatar
nearest dealership is 2 hrs away.... :?
Old Feb 1, 2006 | 05:15 AM
hahaitzskippy's Avatar
ahhhh...
your suppose to use the stock gasket. it fits perfectly fine and works fine. no leaks or anything here
Old Feb 1, 2006 | 05:57 AM
Fushyuguru's Avatar
Originally Posted by hahaitzskippy
ahhhh...
Without any major creases, stock one should be fine for a second mount. If it's manky, replace it. The MMW mani-plate does a good job of bending the excess gasket material so don't expect another mount after the header install.
Old Feb 1, 2006 | 11:37 AM
Petem's Avatar
the MMW header does not come with the exhaust manifold gasket.. only the maiting gasket between the s-pipe and the mid-pipe.. oh. and a new doughnut... a new exhaust manifold gasket will run you about $30 at the dealer... while you may be able to use the old one... why risk it.. if you install it and get a leak.. you have to pull it apart again... for $30, you do not have to worry about that..
Old Feb 2, 2006 | 01:57 PM
dachmo's Avatar
You dont have to get it a a scion dealer. any toyota dealer should have them because it is the same part on the I4 camry and the RAV4. I know this because I just bought mine yesterday for the MMW header.
The part number is 17173-28010
- Dante
Old Feb 3, 2006 | 05:19 PM
vvti24's Avatar
should i change the donut gasket too?
Old Feb 4, 2006 | 08:53 PM
Petem's Avatar
no.. the header kit comes with a new dougnut..!! however.. you may want to read my update here https://www.scionlife.com/forums/vie...503&highlight= about some leaks i had... look towards the bottom of the first post... 02/4/06
yupinmytC
22
Jul 27, 2024 07:08 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Forced4
Aug 21, 2015 09:22 PM
