help getting the header support bolts off
Old Jun 16, 2009 | 07:03 PM
my06tc's Avatar
Default help getting the header support bolts off
ok...im thinking the bolts for the header itself would be a pain to get off..i was wrong they were easy for me.....but im having a hardtime with the support bolts for the header.......i know there 14 mm.......i used lots of PB blaster..wd 40 and so on.....any advice on getting these off besaides a torque wrenh..i cant get vice grips up in there..i tried sokcets and wrenches but when i tape it with a hammer seems to be slipinng and dont wanna strip the bolts....should i let then car be on and work with it cold
worse comes to worse ill burn them oof..cause dont need them with the after market header
Old Jun 16, 2009 | 09:21 PM
elcapetan's Avatar
breaker bar that's what it took for me
Old Jun 16, 2009 | 09:40 PM
weezyfbayba's Avatar
i used an extension and a belt changeing tool lol its skinny so it worked perfect u can get one for like 20$ at advanced auto
Old Jun 16, 2009 | 09:41 PM
ecko04's Avatar
Impact drill/tool FTW
Old Jun 16, 2009 | 09:50 PM
x_Batman_x's Avatar
those bolts are a huge pita.
I honestly wasnt strong enough to do it, I had to get one of my friends over to remove my stock header hahaha
Old Jun 16, 2009 | 10:00 PM
ecko04's Avatar
Sorry, I had to do it
Old Jun 16, 2009 | 10:43 PM
skinnayyy's Avatar
Team Scionara
if you're talking about the support bolts that mounts the header to the brackets that are attached to the frame, i just took the brackets off the frame because it was easier for me to get those off. Just a heavy socket wrench with a breaker bar on that and they come off no problem. You only get a tiny bit of a turn each time you can move it, but it works a lot easier than the other approach. Also, i got the bolts off from the top not from the bottom. only the spring loaded ones i did from the bottom. Hope i helped! ^_^
Old Jun 17, 2009 | 12:41 AM
my06tc's Avatar
i was lookin at that after i spent awhile trying get the side bolts out....
do you think i ts easier for the top then the bottom.....all you used was the socket wrench and a breaker bar no hammer.....thats the only thing that is stopping me the rest was no problem
Old Jun 17, 2009 | 12:44 AM
AcidDrop's Avatar
x2
Old Jun 17, 2009 | 02:23 AM
cburglb34's Avatar
took me a drink of red bull.....i just unbolted one of the brakets completely and the othe rone was fairly easy after the red bull but yea...breaker bar would have helped so get it
Old Jun 17, 2009 | 08:48 PM
my06tc's Avatar
well i got it off....i just took off the two support brackets that connect to the fram i use the breaker bar and 24 mm socket gave it little bit of pulling and boom came loose...as they say breaker bar never lets you down..everything is good now.....someone wanna lock this thread go right ahead
Old Jun 17, 2009 | 08:54 PM
skinnayyy's Avatar
Team Scionara
yeah no hammer needed when getting the bracket bolts off. just the breaker bar. I didn't have a lift or anything so i was underneath the car and a breaker bar wouldn't fit underneath so through the top was the only way fo rme. The header bolts though i used an open socket and a hammer for the ones on the header itself.
Old Jun 17, 2009 | 11:05 PM
my06tc's Avatar
actually the stock nuts that tightens the header itself didnt work for me...as i was tighten then they all lost strength pop off and strips the thread so i had to buy new nuts and washers....i guess thats why they recommend you use the studs that come with the header so it can with stand the force..some say you can use all oen stuff but didnt work for me only thing i reused was the donut other then that and the stock studs.....very shocked that the stock nuts pop loose
k1114
43
Mar 1, 2023 03:08 AM
Greg S
Jul 21, 2016 07:28 PM
rshissler
Mar 24, 2015 10:46 PM
jackmott
36
May 12, 2004 03:48 AM
