Help, Possible AC Problem
I am concerned about the AC condenser on my car. To start its a 05 FM Tc with about 60XXX miles on it. Now heres the possible problem, Whenever I turn on the air(without the a/c on) everything works fine. But now as a switch through the different vent modes, as soon as I get to the one where it Vents by the windsheild and towards the feet, I hear and feel the ac clutch kick in and it blows cold air. If i press the a/c button with that setting on theirs no change, i can't feel it kick in like it does with the other vent settings. Anyone know what could be the possible problem?
Cliff's
A/c kicks on(without button selected) when switching to windsheild and lower vent mode
A/c button has now effect when in the mode.
It only kicks on by itself in that mode.
Everything else works normally
What could it be guys.
Should I try reseting my battery, take it to the delearship?
Cliff's
It is normal that the ac turns on when you select the windshield and the windshield w/floor position. It's to remove the humidity in the cabin so it does not fog the windows. There is no manual override for those settings. So now, what is wrong or what is your concern with the condenser?
No, its always done that because its the "defrost" position for the air unit. It's always happened, you've just finally realized it.
RY_TC07
Jul 18, 2017 05:18 PM
