How bad is this for my engine?
Mostly everyday I do a 50 mile commute from where I live from my house to my work. Everyday when I go on the freeway my average speed is about 80-90 miles per hour and usually never slower than that. The thing is my RPM stays at about 4,000-5,300 for about 30 minutes straight and the tc really needs a 6th gear. Just wondering if it will blow up on me or kill my engine like real fast? How bad is this gonna be for my engine?
^^ thats good advice. Definitely use a synthetic oil like mobil1.
Your engine is sitting around 5300rpm?? Isn't that like over 100mph in 5th? What are the speed limits over there? Slow down!
I agree with you though, it would be nice to have a 6th gear
As mentioned, perform oil changes and other maintenance and you'll be fine. Of course the thought of extra wear and tear may be present but the motor should still be A-OK.
oh I live in LA... the speed limit is around 55-65 but in cali... nobody follows the speed limit.
as for the oil change my engine only has about 5,000 miles in it and i only did the oil change once from the dealer. I don't really know how to do the oil change myself but I use whatever oil the dealer gave me.
I have a small off topic question..I drive an automatic, and I was just curious on whether it's okay for me to shift to neutral while going down a hill. I know it saves gas, but very little, also I enjoy the extra speed I gain. But besides that, I was wondering if this damages anything in any way?
*off topic answer*
well in an auto, what you really should be doing is shifting into a lower gear for engine braking. Shifting into neutral on a hill isn't the best thing to do. Not too safe either.
What kind of wear? well, driveline stresses of neutral to drive but since you picked up speed and the transmission was in neutral. the torque converter will have to spin up, which can lead to a jerk of power into the differential as well as the gears. I wouldn't do this on a normal basis, just shift to a lower gear if you need engine braking.
Originally Posted by sciontc_mich
*off topic answer*
https://www.scionlife.com/forums/vie...124680&start=0
Definitely do it yourself. It is the 1st thing I ever learned to do on a car and it couldn't be easier...especially on this car. SO simple. Just go out and buy a filter wrench (not a strap filter wrench but the kind that fits onto a socket wrench).
Also, if you have an '05, go buy mobil1 5w-30. If you own an '06 or '07, go buy mobil1 5w-20. You can buy it at walmart for around $6 a quart. And of course a mobil1 m1-103 filter. DO NOT use the dealers oil and filters. It is generic crud. I say this with such authority here B/C of the type of strain that you do put on your engine. Once you have that in, change it every 5K. But all of this is in that thread, just read through it and you'll be good to go.
IF I were you id do an oil change ever 3k or 4k. 5k to me is a bit long. I personally do 3k since im turbod anyways.
also I like to pour about half a quart of new oil through the engine b4 plugging it back up and refill. make it extra cleaner
I don't know what your dealers use, but the one closeby uses toyota (Denso) filters and they are one of the best. I even sawed them open and compared. Also, most aftermarket filters give our engine smaller filters, ones meant for the 1.8L engines.
The M1 filter is a little overpriced as well. It's made by Champion Labs, and often shares the same design and build as Bosch, STP, Supertech.
Changing your oil at 3k for Mobile 1 is pretty much a waste of money - it is supposed to be good for many more miles than that. Also driving that small a car at those speeds is not a big strain on the engine when it is reving that much - you probably are barely pressing on the gas pedal. If it were an xB it would be different - I hear they start to cook after about 20 minutes at those speeds. Turning 5k at 90 sounds a little bit high however and I would be thinking more about changing the tranny fluid sooner than the engine oil. Check the oil color and watch for it changing color as it breaks down.
After my brother spun a rod bearing in his car b/c he wasn't using an OEM filter (oil starvation) I would never use another off-brand filter no matter what. The price difference isn't worth the risk IMO. Also, I'll agree with keeping up on the maintence since its being driven in a higher rpm than "normal."
Illusion: You bought an automatic for a reason, leave it in gear. Brake parts are cheaper than transmission jobs. I don't know why people feel the need to enginebrake in this car, unless you are carrying a large load (note
lose to max rating) its unnecessary. Save your tranny, use the freaking brakes.
06 and 07 model tCs take 5W-20.
