How to Clean your Throttle body?
I need some help I've never done this I've searched and can't find anything on it and I hope this is posted in the right if not Mods move to the correct place spot.
Is there any one that can help?
__________________
__________________
what i would probably do is take it off and use some brake parts cleaner in it and an air compressor to blow the residue out.....not 100% sure though so get a second opinion
Do not use brake cleaner, use throttle body cleaner. Remove the hose to the throttle body, have someone with the key in the on position hold down the throttle pedal. Follow instructions on the can.
The standard interval (not Scion specific) is 30K miles. If your local pump's gas is nasty you might want to check earlier.
Once you have a look at the throttle body, it's usually pretty obvious if you need it or not.
______
______
Originally Posted by t_dub
The standard interval (not scion specific) is 30K miles. If your local pump's gas is nasty you might want to check earlier. Once you have a look at the throttle body, it's usually pretty obvious if you need it or not.
gas never flows over the throttle body....
That is correct...the throttle body is the air inlet the fuel is delivered via direct injectors. A 30K check certainly wouldn't hurt anything... your filter will remove damn near all of the contaminates in the air... whether its stock or if you're running a CAI. If you keep your filter replaced/cleaned when you're supposed to... you probably wouldn't have a need to check the T.B. unless you notice a problem.
Originally Posted by Degooch
gotcha thanks
Is their a diy on how to take it apart?
Anytime you take off your air inlet pipe...stock and CAI alike... be extremely careful and have a CLEAN lint free shop towel handy to put in the opening after you take it off. Because it goes without saying that anything at all that gets down into the engine via that inlet....and you're seriously screwed.
true.....there is a way to avoid that, that isnt very expensive... you could setup a catch can...I've seen a number of people with tC's install it below the battery tray... that will help filter out all the crap that could normally get pulled in. They are cheap and easy to install.
