how much power loss? ill be driving with lower compression
the stock scion tc has 9.6:1 compression ratio. I have 9.0:1 compression ratio pistons. I know that there will be a power loss. But how much? noticable difference? I was going boosted but now i'm planning to get rid of the turbo. I'll be running full exhaust system, cold air intake, and other stuff i can do with N/A. I also increased the bore size for the block to 89mm.
I wanna know how much power will be lost (if any) if i run a NA setup with 9.0:1 compression pistons.
Is 9.6:1 a big difference compared to 9.0:1? thanks.
Originally Posted by draxcaliber
yes, why are you going to do all this to make your tc slower and get poorer mpg if your not going turbo?
you'd be better off selling your engine and replacing it with a junkyard engine so you'd atleast be back stock.
if your so tired of boost, (how does that even happen?) why don't you just turn down the boost? so that way you can not be slower and weaker than stock, but not have as much boost?
Originally Posted by BlackKnight
Your going to loose at least 10-15 across the entire power band and it will be a significant difference.
y r u asking about lower compression pistons here then sumthing different in another thread
https://www.scionlife.com/forums/viewtopic.php?t=255555
hampton1100
May 28, 2015 07:32 AM
ScionVan
11
Dec 2, 2003 09:37 PM
