Installed camcon and intake. Dyno inside. *W/ Time slips*
Old Apr 26, 2007 | 04:02 PM
Neothin's Avatar
hahaha i was wondering about the MPH on the las pass
i run 225/40/18 falken azeni's st115's. quick slip of the clutch from 3k
Old Apr 26, 2007 | 04:32 PM
KCTTC's Avatar
My first pass I slipped it at 3500, second pass was 3000 and third pass was 2500.
I just ordered some bfg drag radials. I am going to finish tuning the camcon next week and hopefully hit the track soon after that.
Old Apr 26, 2007 | 04:37 PM
Neothin's Avatar
245 width tires and you still cant hook off the line? come on now...
then again, i cant say anything. I spin the hell out of 75% of my launches because i slip the clutch and add gas so aggressively. It's literally either a great launch or a smoke storm
Old Apr 26, 2007 | 04:51 PM
KCTTC's Avatar
The Kumhos tend to do a little better in the corners. I have a set of slicks but can't run them now because of the BBK. I have had real good luck in the past with the bfg's but I have never used the 225/45-17.
Old Apr 29, 2007 | 07:34 AM
kikcaffine's Avatar
So does this thing come with any type of preset tuning map?
Old May 1, 2007 | 02:31 AM
tcdaily's Avatar
^^+1 on preset maps. and also do you have to use 91 gas now, because gas is freakin' expensive. and i didn't know that we coul adjust the cam timing without different cam gears?
Old May 1, 2007 | 05:02 PM
KCTTC's Avatar
I have seen people post up different maps for others to use but every car is going to be different. No two cars are going to have the same afr maps. I also tried a couple of different people’s cam timing maps and I still came up with a totally different map for my setup.
I did switch to 91 octane because I am running between 13.2 and 13.5 afr. I figure better safe than sorry. I to was worried about the extra cost of fuel but I have noticed an increase of around 75 miles per tank ever since I tuned the camcon.
The cam timing on the tc is electronically controlled by the ecu.
-Jeremy
Old May 1, 2007 | 06:13 PM
diminishedpower's Avatar
maybe I'm just ignorant, but if the camcom only tunes WOT and the ecu takes car of rest how can you get an increase in gas mileage of that much unless your running WOT 24/7?
Old May 1, 2007 | 09:02 PM
KCTTC's Avatar
That’s what I been trying to figure out. The camcon adjustments seem to be strictly rpm based so it is constantly making the selected changes at the given rpm. When we were done tuning on the dyno we checked the part throttle a/f to see what it was at cruising speed. It was between 14.5 and 15.2. With the Camcon off the a/f would richen up between 13.5 and 14.2. I can't explain why this is when it is only supposed to adjust wot. I am going to try and contact Power Enterprise and see if I can get any more information.
-Jeremy
Old May 1, 2007 | 09:13 PM
ok so I wasn't going nuts and thanks for the info
Old Jun 26, 2007 | 09:29 AM
midnight_blue's Avatar
yes great info i too am bout to invest in camcon
Old Jun 27, 2007 | 12:53 AM
toyota_scion_tc's Avatar
My tC weighed in at 2930 on a certified scale. As far as the camcon I had no luck with it. At first my car liked it then after a few more mods it didn't like it anymore. And yes I reset the ecu and tried again and still my car was running too rich. So I upgraded to the Greddy Emanage Ultimate and I love it but it still lets my car run rich from time to time. I am not going to worry about it now b/c I am taking a job overseas and when I return I am building a custom engine, transmission, and turbo kit for the tC and I will have a standalone ecu then.
Old Jun 27, 2007 | 01:50 AM
KCTTC's Avatar
Last time I had the car on the dyno, I was able to finish tuning the camcon. It put down 166 whp and 164 ft/lbs. I have had my car on the dyno 3 times since I installed the camcon on and the tune has stayed consistant.
-Jeremy
Old Jun 27, 2007 | 01:51 AM
wat were the numbers before the camcon
Old Jun 27, 2007 | 01:57 AM
KCTTC's Avatar
They are in the original post on the first page.
-Jeremy
Old Jun 27, 2007 | 02:00 AM
for your camcon did you hav to do any splicing, and future mods
Old Jun 27, 2007 | 02:27 AM
KCTTC's Avatar
I soldered all my connections.
Future mods:
1) Volk 17x9 wheels, 255/40-17 Falken Azenis RT-615
2) Clutch. flywheel, diff
3) AEM ecu
4) CP 11:1 Pistons, ported and polished head, supertech valvetrain, cams
5) Seats, harnesses, gauges, 6pt roll bar
Old Jun 27, 2007 | 11:15 AM
btw the computer actually does a good job with the vvti system if you want biggest gain get something that controls ignition timing and fuel.
Old Jun 27, 2007 | 03:14 PM
FIREDOG's Avatar
hydra comes with cam controller :-)
Old Jun 27, 2007 | 09:50 PM
asthmatic's Avatar
Future mods:
3) AEM ecu
17x9? haha youre crazy
