Intake Problem....What's causing this
Old Nov 9, 2005 | 05:19 PM
jaytizzle's Avatar
Default Intake Problem....What's causing this
I installed my intake the other day and now my car idles funny until it is warmed up. Is this normal or should I be worried?
Old Nov 9, 2005 | 05:31 PM
ScionDad's Avatar
What intake?
Old Nov 9, 2005 | 05:34 PM
xavier's Avatar
are you throwing a cel?
Old Nov 9, 2005 | 05:44 PM
Stu_Gotti's Avatar
Hmm.. Everything is hooked up right? Did you disconnect your battery and then install and reconnect? Everything tight.. if so... then It might just be normal.
Old Nov 9, 2005 | 05:54 PM
dmxsoulja3's Avatar
This is normal, I swapped for CAI at 400 miles so I didn't have time to take note to what it was like stock, I traded in my tC and switched it back to stock the idle when it was cold was much smoother with the stock airbox.
Old Nov 9, 2005 | 05:58 PM
tcengel's Avatar
If you have the secret weapon intake, you need a thicker rubber o-ring around your MAF. You can buy a set of misc. sizes for cheap at your local auto store.
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
cabphil62
May 18, 2012 05:53 PM
Scionic
199
Jan 8, 2006 11:09 AM
arinvolvo
Jan 21, 2004 11:40 PM
CBSIMONSEZ
29
Jan 2, 2004 09:57 PM
