Just Installed Injen CAI on my 08 tC
Here's some pics of the Injen intake installed on my 08 tC. One of the vibra-mounts came broken so I went to my local ACE Hardware and picked up a couple parts and made a completely perfect replacement vibra-mount. I am still emailing Injen and having them send me a new one. But here's what I did...unfortunately I didn't think to take pics till after I did the install and the fabbed vibra-mount is inside the fender. But this is basically what I did:
Broken Vibra-Mount
M6 (6mm) Bolt:
Rubber Stopper w/ hole:
6mm Fender Washer:
Everything fit like a champ and I had absolutely NO fit problems like NUMEROUS people stated w/ the Injen. I also used Doc I's fender panel.
Broken Vibra-Mount
M6 (6mm) Bolt:
6mm Fender Washer:
haha, thanks...I should also note that I removed the front bumper which I believe made the install 10X easier than trying to mess w/ aligning the pipe through that hole w/ just the splash guard folded back. If you're going to install this intake..or any CAI..I would spend the extra 10mins and remove the front bumper. It will save you time in the long run I'm sure.
Originally Posted by tcCAlI
waste of money really! just save up for f/i.
Originally Posted by baaam
You dont need to take off the bumper to install the Injen Intake, just peel back the wheel well lining and its cake
Neither of them are CARB legal......here's INJEN's page on both intakes:
http://injen.com/docs/other/search.a...lID=141&Eng=L4
Under the column heading "EO#" they both say No CARB
hm.. weird... cuz when i got mine... i was told the Chrome was CARB legal cuz something about it was the 1st for the 07 made so they didn't want to go thru the hassle of gettin the black one CARB legal.. some BS about that they cant give it to both because they're not the same thing.. idk i'll check it out later i know it said somewhere it was CARB legal.
it gives you like .5 hp
https://www.scionlife.com/forums/viewtopic.php?t=92108
