KillertC.com/GSCMotorsports.com Scion tC Intake Test !!!!
Old Nov 12, 2005 | 10:21 PM
  #61
KillertC_com's Avatar
I will have some pictures of the Exhaust a sound clip and a dyno graph for all to see next week. I have not even seen the exhaust yet, but its on the way here now.
as far as the Vibrant website its at www.vibrantperformance.com great quality exhaust products. we have been selling there WRX/STi exhaust and header for a few years now. Here is the link to there other exhausts we carry http://www.gscmotorsports.com/categories/?id=3641 you can see the quality in the other exhausts.
As far as cost its obviously going to be more than just an axel back but should be in the $600 range maybe a little more but we will see. I know the tC exhaust is very similar to the mazda 3 exhaust on the GSC site.
Greg
Old Nov 12, 2005 | 10:35 PM
  #62
engifineer's Avatar
I would be more interested in seeing an average of three runs with each intake. With the run, switch, run switch method you are not completely cooling down, and you are only taking one data point for each, which completely neglects variation. It isnt a bad test, dont get me wrong, but I would like to see more statistically sound data before basing the type of intake I use off of it, mainly because of the small differences between each. Just my .02 though.
Old Nov 12, 2005 | 10:38 PM
  #63
engifineer's Avatar
Originally Posted by Limey
OK could someone explain HOW and WHY the SR version of the injen performed so much worse that it's CAI sister.
The only difference is a foot of curvey pipe.
How in technical terms could this affect the A/F mix, how could it affect the MAF.
Surely once the air reaches the SR position in the pipe it's the same air doing the same thing. It's just airflow in a pipe, right.
It doesn't make any physics sense, atleast not to me.
The SR is drawing heated air from inside the engine compartment, which is less oxygen dense... thus, less fuel can be burned at a time (same reason you run a FMIC with a FI setup). So basically they are WORSE than stock in that area since the stock airbox draws from the fender well. They are better than stock in the sense that they "should" be more free flowing.
Old Nov 12, 2005 | 10:45 PM
  #64
well we did let the car cool. it takes at least 10-15 minutes to change the intakes. and as far as letting it cool totally inbetween runs then it wouldn't be a true real world test. sense we did test all the intakes the same way giving each intake the same cooling method should net close to the same margins if we let each run cool back to ambiant temp.
The main reason for doing 3 runs was to adapt the ecu or mass air before the final pull.
Old Nov 14, 2005 | 08:55 PM
  #65
Mica's Avatar
Originally Posted by KillertC_com
Also I will put the K&N Drop in and the stock air box test up today. just got to get to the office to get to the computer.
I would still like to see this
Thanks!
Old Nov 14, 2005 | 10:47 PM
  #66
Acsilva84's Avatar
thanks for the numbers. this kinda sucks because i just baught a k&n drop in filter....
maybe i can return it.
Old Nov 15, 2005 | 12:01 AM
  #67
senseiturtle's Avatar
Thing is, while there is no difference between stock and K&N by just dropping in the filter, the AF ratio is a bit better.
I think you'd actually see a difference on a modded airbox setup. Its the stock intake plumbing below the filter that's terrible.
Old Nov 15, 2005 | 02:45 AM
  #68
Sorry it took so long but here is the Stock VS K&N Drop In Filter
Also wanted to let everyone know that Weapon R is sending us one of there intakes for testing. we will compair it to the Injen CAI that is on the car.
Old Nov 15, 2005 | 03:21 AM
  #69
-NEMESIS-'s Avatar
this ought to be interesting injen or weapon errrr monster R works . thanks for doing this guys....it is great to see actual data than just hear say and butt dyno's. no test is actually going to be 'perfect' or satisfy everybody, but thanks for doing your best.
Old Nov 15, 2005 | 03:31 AM
  #70
-Keith-'s Avatar
Yea im with Nemesis...
I have a question you said you let the car cool down for 15 minutes... what was the first intake you tested that day?
Old Nov 15, 2005 | 03:36 AM
  #71
Jowie's Avatar
Greg
I used to have the vibrant axle back on my 98 Neon RT. I really liked the sound. Was nice and deep, not even a hint of rasp. I'm very interested in the vibrant kit for the tC. I wanna hear it first tho!
Old Nov 15, 2005 | 05:27 AM
  #72
Thanks for the dyno. I really thought the stock filter was more restrictive than that, but at least it never needs replacing..
Old Nov 15, 2005 | 01:49 PM
  #73
First tested was the K&N CAI the Stock, then K&N drop in, Injen CAI, Injen Short, and F5.
Weapon R and maybe umajitiawanatouchthehinny might be sending in there intake. Just got an email from them. All i got to say is sure would have been nice to have them to include on the first round.
I'll try and post the info on Sunday we will try and do it then.
As far as the vibrant goes we will do a sound clip and give our opinion of the sound. and trust me when we say something sounds like crap we will tell you.
Old Nov 15, 2005 | 02:11 PM
  #74
Fsu1dolfan's Avatar
Keep up the good work...thanks a million!!!!
PS.
You should ask Draxas.com if you can test his Exhaust........
I have the Injen CAI and the Draxas full exhaust and the thing pulls beauitfully.....i work love to see the numbers....it is also a 2.5 with high flow cat straight through with medral bents!!!! I love the sound!!! Just a thought...
Old Nov 16, 2005 | 04:11 PM
  #75
Bavtoys's Avatar
Intake leaves today. Subscribing for results.
Old Nov 16, 2005 | 07:24 PM
  #76
Jarrod123's Avatar
can't wait to see the results. these threads are great!
Old Nov 16, 2005 | 08:10 PM
  #77
zygote's Avatar
It'd be great to compare the CreativeCompacts header-back exhaust with the Vibrant one, when you get around to that....
Old Nov 17, 2005 | 01:19 AM
  #78
Acsilva84's Avatar
with the k&n drop in filter, would it have been better if the ecu was reset? would i get better gains with this filter is i already have a creative compacts catback?
Old Nov 17, 2005 | 05:10 PM
  #79
ColeGSC's Avatar
We received the Weapon R intake today and we are waiting on the Umnitza intake. I think the Umnitza was shipped out yesterday, hopefully we will see it before the end of the week.
we will test both of these and post the results for you as soon as we can.
Old Nov 17, 2005 | 06:05 PM
  #80
BIGRKtC's Avatar
Great thread guys!
I'm only chiming in so I can track it.
