Leaking from engine help!!!!!
What I think it is,is oil running down from the engine cover,right above the circled thingy is that nut that can be loose.There is 10 of then that hold the cover in place.Take a 10mm socket an tight them,take a rag and wipe the drippings off,engine vibration with time will cause those nuts to become loose,I've done it a few times....hope that helps!
That makes good sense, I will tighten them down since I never have! But I know for sure I saw it coming out of the circle thing. I had someone else start if up when I saw it. It is almost like there is too much oil pressure and so it is pushing through that point. IDK
DaBlackBox
134
04-10-2022 02:04 PM
