maf sensors
Old Dec 12, 2006 | 09:36 PM
305rs1tc's Avatar
Default maf sensors
i want to run a 3 intake but it keeps throwing a code and then the engine just boggs down and pretty much has the ecceleration of a ford pinto! my question is is there a maf sensor on other toyota plat forms like a v-6 camary or am is there a way to bypass the maf sensor completely? any suggestions greatly appreciated thanks!
Old Dec 12, 2006 | 09:43 PM
chrischoi's Avatar
uhhh.... a 3 intake?
you mean a3?
Old Dec 12, 2006 | 09:45 PM
305rs1tc's Avatar
3 inch diamiter intake my bad
Old Dec 12, 2006 | 09:49 PM
SquallLHeart's Avatar
bypass maf?
could always shove a resisitor in there...
honestly... no. i assume you're getting a cel...?
Old Dec 12, 2006 | 09:52 PM
305rs1tc's Avatar
yup cel i hate that dam thing lol
Old Dec 12, 2006 | 10:06 PM
btw.. did you just make your own intake....?
Old Dec 12, 2006 | 10:16 PM
305rs1tc's Avatar
yeah im broke so i made an intake from the diy parts at pep boys!
Old Dec 12, 2006 | 10:23 PM
chrischoi's Avatar
wow. so it's just a pipe. not a intake.
Old Dec 12, 2006 | 10:24 PM
TCpete's Avatar
just because the intake tube is the size of an elephant ***** does not mean your going to make HP... if your broke just drop in a k&n filter at the least inside the air box... or take out the box all together and were the tube ends just after the sensor put a cone filter there. dont use pep boy tubes to make that kind of stuff.. in the end its money down the drain and more of a headache to work around problems like u have..
also i hope u reset the ecu and let it run normal for about 10 minutes when u did that instead of just flooring it right after you did it.
Old Dec 12, 2006 | 10:36 PM
Old Dec 12, 2006 | 10:48 PM
soros151's Avatar
Air velocity is at it's worst I think for it to Bog down that much.
Old Dec 12, 2006 | 11:25 PM
MJVsTC's Avatar
Haha. He said "elephant *****.
Old Dec 13, 2006 | 12:47 AM
kikcaffine's Avatar
Just put a stock airbox back in and cut a bunch of holes in it. It will sound like it has an intake and will be loud. There ya go! Send me 5 dollars please!
Old Dec 19, 2006 | 10:16 PM
BOXMAN's Avatar
The issue is the MAF is seeing lean/rich conditions and dosent know what to do so you bog down and power suffers. There is a reason intakes go through R&D.
MeDizzy
Oct 8, 2015 03:31 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Gigs
Sep 15, 2015 03:54 AM
Topfueltom69
Sep 6, 2015 05:25 PM
