Megan Header installed, I have some problems/question.
I put this header on my car yesterday, I was kind of shocked how they didn't include any bolts at all. The bolts on the brackets are connected to the stock header so you have to find & purchase your own bolts.
Also, when I bolted the megan header to the S-Pipe I noticed that it didn't seem completely air tight. Everything did line up, and the bolts did turn until they were very tight.
I had my friend go inside the car and rev it up a few times and I noticed that I felt a small ammount of air come out where the header connected to the s-pipe. I was wondering if this is normal or not?
Below 3,000 rpms the car seems to have a much different sound to it, above 3,000 I can't notice any of a difference because the K&N intake is so loud.
I really don't see any other possible way to connect the header to the s-pipe because the holes & bolts line up perfectly.
I did notice a performance gain (I can very easily chirp 3rd now), so I figured it was installed correctly.
PS, If anyone is wondering, I didn't get a CEL because I installed the spark plug anti-foulers.
Any advise would be great. Does everything I posted sound normal?
To be honest, there was no instructions that came with the header.. and when I took off the stock header I didn't even notice a gasket between the s-pipe & header. Do you have any pictures of what you're talking about?
I'm guessing not having a gasket in between might be causing this problem. If I can't find or remove the stock gasket should I be able to find one at any autoparts store?
Sorry for all the beginner questions, I have never installed a header before.
Hmmm... I may have missed the S-pipe gasket myself... there's a LOT of exhaust smell coming from the front of the car... the actual header gasket and header bolts are secured very tightly, and I didn't feel any leakage from there. I bet that gasket is still in fact on the stock headers ahhaahaha... I'm an idiot, but hey, Megan didn't include anything with their headers except for decals.... goody
Originally Posted by English
yeah it probably sounds loud as hell from the front too...that's what happened with me
Last time I used ramps I nearly took my buddy's foot off. It was my first time using them, and applied the gas to back off of the ramps to realign them, not thinking of course, and shot both ramps out from underneath the car and into the garage wall. They ejected with so much force that they got stuck in the drywall....
I think I'll stick with jacks for now
Originally Posted by falcon9094
what size bolts did you buy?
these are for the stock brackets that the Megan header hooks up to.. the bolts that are in there originally are perminately connected to the stock header.
Originally Posted by TurboTC
Those bolts and brackets came off my factory header. It took a little muscle but they came loose.
It would probably be easier if you loosened them before you remove the header.
i don't see how it would be possible to remove those bolts without ruining the threads on it. the only thing you can grab onto is the threads.
Well, I just received the CEL after driving about 20-30 miles. I have the 2 spark plug anti-fouler's installed also. Is there anything else I can do to fix this problem?
I haven't tryed to disconnect the battery yet but I highly doubt that would help in the long run.
