Megan Header installed, I have some problems/question.
Old Apr 6, 2005 | 05:27 AM
DouBLeJ16's Avatar
Originally Posted by English
are you sure you put the anti foulers on the 2nd o2 sensor on the s pipe after the header?
Yes it is, I actually installed the anti-fouler's on the s-pipe before I even received the megan header.
Old Apr 6, 2005 | 02:33 PM
thelast60's Avatar
i got my Megan headers yesterday and tried to put them on but failed. couldnot get the bolts off the exhaust pipe. I am glad to hear they work so well, can't wait to have them on.
Old Apr 6, 2005 | 04:09 PM
Giravani's Avatar
If that didn't work for you, and it's odd that it didn't, then you're only other option as far as I know would be to purchase an O2 simulator. It's basically a cap that ports into the stock secondary O2 sensor clip and feeds the ECU lies.
For the mounting bolts on the bracket, what I did was give them a good shot with WD40, wait a couple minutes, tap the metal around the bolts with a hammer, and twist them right out. They're threaded on both ends (externally, and inside the hole). One of them did give us trouble but we used a pair of locking vice grips on them with the bolt wrapped in a rag and it came right out.
It's really strange that the antifouler didn't work... did you tighten down the secondary sensor tight enough? What about the first? If they aren't secured tightly they'll toss you a CEL.
Good luck man!
-Adam
Old Apr 6, 2005 | 09:38 PM
DouBLeJ16's Avatar
yeah, they were all tight.. i double checked just now. I just reset the ECU, and it turned off. I have drove around with it yet, I'll let you guys know if it comes back on.
Old Apr 14, 2005 | 10:55 AM
DouBLeJ16's Avatar
I drove around about 50-60 miles after resetting the ECU and the CEL came back.
Old Apr 14, 2005 | 02:11 PM
CreativeCompacts's Avatar
Very wierd situation... instead of guessing the issue which would be like trying to find a ghost, simply get the car scanned to see where its coming from. You could of damaged an O2 Sensor during install.
Old Apr 14, 2005 | 08:01 PM
Diluvium's Avatar
DOES ANYONE HAVE A VIDEO CLIP OF THE MEGAN HEADERS????? i wanna hear this "rasp" sound that people been saying!
Old Apr 15, 2005 | 05:47 AM
DouBLeJ16's Avatar
I had it checked yesterday at the dealer and they said it's happening because of the header.
Old Apr 16, 2005 | 04:28 AM
DouBLeJ16's Avatar
today I started up my car and heard an odd noise, it sounds like something is trapped inside of the exhaust.. it rattles around a little bit. I'm sure everything is installed right, and the sounds is definately coming from inside the exhaust pipe (it sounds like it's in the s-pipe) is this normal when the megan header is breaking in?
I might take it apart tomorrow and find out what it is.
Old Apr 16, 2005 | 08:32 AM
English's Avatar
def. not normal
Old Apr 16, 2005 | 02:22 PM
i64X's Avatar
You didn't drill out BOTH of the anti-foulers did you? You're only supposed to drill out the 'first one'...
O2 Sensor -> Drilled Anti-Fouler -> Non-Drilled Anti-Fouler -> Exhaust Pipe
...like that.
I did the anti-fouler trick with my DC and I'm over 250 miles with no CEL.
Old Apr 17, 2005 | 04:59 AM
DouBLeJ16's Avatar
i just dropped pretty much the entire exhaust and found a piece of a cat that was built into the megan header.. i believe this is why I was getting the CEL. i'm worried other pieces might break off inside the header. I'll be contacting them to see if they can replace it.
the piece of cat was alot the size of a golf ball.
Old Apr 17, 2005 | 01:11 PM
davo345's Avatar
what a sickening display...
Old Apr 17, 2005 | 05:53 PM
English's Avatar
lol I'm sure that piece helps the header flow well!
Old Apr 18, 2005 | 01:37 AM
DouBLeJ16's Avatar
seems like they're making a new design in june and they will replace it for free.. that's good to hear.
Old Apr 18, 2005 | 02:51 AM
Diluvium's Avatar
NICE!
so whats with your headers now?? is it installed or you switch it to stock?? so does the car sound louder??
Old Apr 18, 2005 | 04:54 AM
DouBLeJ16's Avatar
the megan header is still on, sounds pretty good now.
Old Apr 19, 2005 | 12:54 PM
i64X's Avatar
I'm glad I bought a DC
Old Apr 19, 2005 | 07:10 PM
English's Avatar
me too!
Old Apr 20, 2005 | 04:39 AM
acasanova's Avatar
glad i got alphawerks..so far.
