Megan midpipe and spipe problem
Old Dec 21, 2006 | 03:42 PM
3min3m2's Avatar
my megan s-pipe nad mid-pipe both rub in quite a few plaes....have fun
i know i wont buy that exhaust again, it just wasn't fit well to the tc.....
Old Dec 21, 2006 | 10:54 PM
chrischoi's Avatar
Originally Posted by BionicJuic3
So if i have the TRD Axle back would that fit with the Megan Midpipe to the S-pipe?
yes. i know someone who has it.
Old Dec 22, 2006 | 05:51 PM
thebigjdub35's Avatar
How hard is the install? Is it something that just bolts on?
Old Dec 26, 2006 | 04:44 PM
BOXMAN's Avatar
Has the first post been answered? Also when did this turn into a general exhaust thread? Megan racing can be contacted direct once you do that they can solve your issues or put you intouch with someone who can/sells megan racing parts. Any more questions?
Old Dec 26, 2006 | 09:20 PM
hmflinttc's Avatar
I had the same problem - my megan s-pipe wouldn't fit into my megan midpipe. Fortunately, before I decided to break out the power tools, I decided to call Megan. Apparently, the hardware included with the s-pipe is supposed to include a spacer flange that goes in between the s-pipe and midpipe. I guess it covers up that little extension of piping. The Megan guy said if you are using the megan midpipe, you have to use this spacer flange because it is smaller (in diameter) than the s-pipe. He told me to contact the place that I bought it from to get the flange. Apparently, Megan recently started including the flange and I got an older s-pipe. In the meantime, I'm running the stock s-pipe, which fits perfectly into the midpipe. It sounds great by the way - I have the full OE-RS exhaust.
Old Dec 26, 2006 | 09:28 PM
BOXMAN's Avatar
That wasnt very helpful of Megan Racing they should have just sent the piece to you not made you call around for them.
Old Dec 26, 2006 | 10:19 PM
hmflinttc's Avatar
Yeah i know haha - hopefully I'll have it soon. Ray at House of Scion said he would get it to me ASAP.
Old Dec 26, 2006 | 10:21 PM
BOXMAN's Avatar
Atleast you have a good dealer to fall back on.
Old Dec 27, 2006 | 01:08 PM
jjos1's Avatar
Funny I just found the other day I have a leak between my cc s pipe and megan mid pipe, I think I have only like 3k on it so far
Old Dec 27, 2006 | 02:32 PM
BOXMAN's Avatar
The CC s-pipe has been known to have slight leaks. I would take it by an exhaust shop and see if they can come up with a solution.
Old Dec 27, 2006 | 02:37 PM
jjos1's Avatar
It has a small leak in the front section the big leak I just found is where the 2 pipes meet the gasket needs to be replaced.
Old Dec 27, 2006 | 03:27 PM
BOXMAN's Avatar
Well anytime a gasket goes bad you will have a leak no matter what. Look for a good muffler shop and ask what kind of gasket they would use to remedy the problem. Maybe they will have a HD one.
Old Dec 27, 2006 | 05:14 PM
jjos1's Avatar
I just ordered a donut gasket from Toyota, the s pipe has a small pin hole size leak in the front in the weld. When I have my wide band senors welded in the s pipe I will get that fixed also. Hope fully the gasket from Toyota will hold up, I'm surprised that Toyota never put and flex section in the exhaust.
Old Dec 27, 2006 | 05:42 PM
BOXMAN's Avatar
Thats why the header is mounted to the block. There is a lot of movement in the toyota drivetrain and this causes weak welds to crack.
xtimxmayyx
Aug 11, 2015 05:29 PM
That_Kid_Ju
Jun 26, 2015 10:57 PM
jaspercanda
Apr 30, 2015 02:39 PM
oreoremix42
Apr 8, 2015 01:06 PM
LoseControl
Mar 26, 2015 02:24 PM
