MT-90 ftw...
Originally Posted by Scoobasteve4132
how was the flush?... Never done it before, but plan on flushing all my fluids prior to my turbo install...
Replaced mine as well with Redline mt-90 and it helped a little. When its cold its still the same but when its warmed up 2nd, 3rd, & 4th goes in easier than before.
I might try AMSOIL next time to see if it makes a difference to Redline.
the initial switch to redline was a HUGE difference though.
+1 on Redline MT-90. Things to watch out for - don't overtorque the bolts when reinstalling and make sure the metal gaskets get back on the bolts. I had the gasket off the drain bolt fall into the drain pan and didn't realize it until I had everything put back together. I had to remove the bolt, put the gasket on, and re-plug the drain without dropping more MT-90 than I had left
