My Dyno
Old Apr 3, 2006 | 01:31 PM
HighlanderMac's Avatar
Well, I decided to do a little research.. and you do learn a few things.
" Different Gears
Back in the May, 1998 Technobabble, I dyno tested a Sentra SE-R in every different gear. Second, third and fourth were very similar, but first and fifth were quite a bit lower. Testing a car in either first or fifth is a little odd, and would probably be noticed by the car owner if they were observing the test. The differences are much more significant on a turbocharged car, though, as the higher gears slow the engine's acceleration and allow the turbo to spool up earlier and stronger. If you do a second gear pull with a turbocharged car, the engine will often outrun the turbo--by the time the turbo is spinning fast enough to make boost at 3000 rpm, for example, the engine will already be going 4000 rpm; by the time the turbo is fast enough for 4000, the engine is at 5000.
This is why turbocharged cars feel so strong in higher gears when pulling up a hill, or whenever they are heavily loaded. If you compare a turbocharged pull made in second gear to a pull made in fourth, the fourth gear run will almost always be stronger. We typically dyno naturally aspirated cars in third gear, and turbocharged cars in fourth.
Another difference that can occur with gearing comes when there is a 1:1 gear ratio available. Most rear-wheel drive gearboxes will have a gear that is 1:1--typically this is fourth gear, but in six-speed gearboxes it is often fifth. In the 1:1 gear in many gearboxes, power is not actually transferred through a gearset; the input and output shafts are just locked together. This eliminates the losses through the gear teeth, and results in a higher power output in that gear."
Old Apr 4, 2006 | 05:11 PM
Kumitsu's Avatar
Sorry for the longwait guys.
I scanned the images but they didnt come out that good you really have to put your eyes into it, Anyways here are the links.
Dyno 1 - http://putfile.com/pic.php?pic=4/9312050639.jpg&s=x10
Dyno 2 - http://putfile.com/pic.php?pic=4/9312055911.jpg&s=x10
Dyno 3 - http://putfile.com/pic.php?pic=4/9312064088.jpg&s=x10
Old Apr 6, 2006 | 04:11 AM
Sam_J84's Avatar
nice numbers dude.
Old Apr 6, 2006 | 07:50 AM
tCing_U's Avatar
whats the size of your s pipe and exhaust pipe-->2.25 or 2.5 ??
Old Apr 7, 2006 | 12:09 AM
Kumitsu's Avatar
2.5 from Creative Compact
Old Jan 26, 2007 | 02:38 AM
BionicJuic3's Avatar
Hey Kumitsu, by any chance do you have a video clip or your car?
Old Jan 26, 2007 | 02:55 AM
Kumitsu's Avatar
no, sorry bud
Praetoriate
Scion tC 2G Forced Induction
Jun 21, 2017 12:58 PM
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
carid
Aug 31, 2015 11:17 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
Mpwr
Jul 17, 2015 08:39 AM
