Need help car speed up
So my problem started about a week ago it wouldn't accelerate so I thought dirty mag clean it but still nothing so order a new one put it in an it helps but still doesn't speed up an now I got this really bad hissing when I hit 4 to 5k rpms Wat do you guys think it can be
Look for signs of soot around manifold. If you do have an exhaust leak then its possible the computer isnt getting correct reading and running lean.
Sent from my SGH-T999 using Tapatalk 2
Most likely exhaust leak if you're not throwing codes. I ran w/o a mid or rear section before and felt like I was hauling a full trailer. Do you have an aftermarket exhaust or stock? Check the connection points for leaks.
Getting Megan s pipe goin to check where the s pipe connects
I was revving engine while someone sprayed seafoam into throttle body an bunch of white smoke came out an drove he seems to speed up but not quite there yet
daniinpitt
Apr 4, 2015 08:07 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
