New Clutch problems
Old Jan 30, 2010 | 04:53 PM
tcdriver2006's Avatar
Default New Clutch problems
Hey fellow scion drivers,
I just put in a new stage 2 clutch on my 2006 scion tc about 2 weeks ago, it has about 100 miles on it. When I drive sometimes when i try to put it in first it gets stuck and I have to turn the car off and on again for it to work.. it doesnt happen all the time but it does sometimes.
/when i am in nutral and want to go first i have to force it up to first sometimes idk is that just part of the "break in period">?
If not, someone told me I need to:
re adjust my clutch..
And
Bleed my clutch
anyideas guys?
and can someone explain ho i can do these things?
Old Jan 30, 2010 | 05:41 PM
TunerKid's Avatar
Sounds like the problem i was having until a week ago when my slave cylinder went out and my throwout bearing exploded
Old Jan 30, 2010 | 05:44 PM
fmtc4ever's Avatar
for me is that i cant engage into gears
Old Jan 30, 2010 | 06:43 PM
SoFloTC's Avatar
i saw this on CSTC and said that the clutch pedal might need adjustement cuz the clutch isnt engaging all the way. what brand clutch did u buy?
Old Jan 31, 2010 | 03:39 PM
F1 racing stage 2 clutch how do i readjust my clutch pedal?
Old Jan 31, 2010 | 04:46 PM
N0AuTHoRiTy's Avatar
Sounds like a throwout bearing issue I also had awhile back. How low to the floor does the clutch pedal travel until it actually engages?
Old Jan 31, 2010 | 06:07 PM
Carlanga's Avatar
adjust it first and then come back with updates
Old Jan 31, 2010 | 08:04 PM
SuperXero's Avatar
maybe you should have bought a better clutch. reviews are mixed. but the majority of them go downhill
Old Jan 31, 2010 | 10:44 PM
SoFloTC's Avatar
someone find the link to adjusting the clutch on the tc.. im not to pro enough to explain im afraid id fail
Old Feb 1, 2010 | 04:01 PM
yea can someone give me a link on how to adjust the clutch?
Old Feb 5, 2010 | 11:04 PM
Scorpius01's Avatar
Where is the engagement? low to the floor? Sounds like an adjustment should be done first befor an assumption can be made that other componets are bad.
there is 12 mm locknut you must loosen, then turn the shaft so that you have minmal play or you find the the clutch engages where you like.
The higher it engages the easier the shifting will become.
Dmmcclair
Aug 13, 2015 07:14 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
yhwhdesign
10
Feb 6, 2015 05:00 AM
baker08tc
Dec 30, 2014 12:02 AM
tC4me
Feb 5, 2004 02:30 PM
