The newest built all motor Scion tC.
Old Aug 29, 2010 | 08:41 PM
  #61
CleanFMtC's Avatar
awesome video. now get us some numbers!
Old Aug 30, 2010 | 01:58 PM
  #62
Spr4yedTc's Avatar
waiting... more lol
Old Sep 10, 2010 | 04:57 AM
  #63
ThaHMan's Avatar
NICE
Old Sep 10, 2010 | 12:07 PM
  #64
trd07tc's Avatar
dyno numbers are for ___s lets see some track numbers
Old Sep 10, 2010 | 10:33 PM
  #65
jimmyjun's Avatar
Originally Posted by Max Hughes
Hmm my RX8 TB picture wasn't posted here well from the video you see we just drilled the rivets out of the rx8 TB that held the circuit board on and replaced it with the Scion TC circuitry. They are exactly the same in dimension and function but the RX8 TB electronics were apparently fried so it was unrepsonsive. That was the reason for the switch of circuitry.
As to how I mounted it I got a 4x4x1 piece of 6061 aluminum from onlinemetals.com for $33. I then made gasket templates by simply brushing black paint on the surfaces of the TB and Intake and pressing gasket material on there to make an outline. I cut the gaskets out with an exacto knife and traced their outlines and holes onto the metal starting with the RX-8 side. I used a 57mm hole saw to make the intake hole and rotated the piece on a 4" bench grinder to make a 'funnel' shape on the RX8 side to match it's 70mm size. After that I got a 1/4" tap set and drilled and taped the four RX-8 TB mounting bolts, drilling about 3/4" down into the metal. Then I moved on to the intake side which I had to be careful with because I made the adapter AFTER I put the damn engine and intake in. If I did it all over again I would have made the adapter first and made sure it fit 100% and THEN dropped in the engine and intake.
You have to be careful that you position the aluminum piece in a way that it doesn't conflict with the intake.
Despite the pic, I used 1/4-20 thread bolts instead of the studs. The nuts proved too hard to get on so I used allen socket bolts and lock washers.
We also bypassed the coolant lines that go to the TB and the fuel vapor thing.
so, all you have to do is change the circuit board, no wires, etc???????? is there anything more that has to be done electrical wise???????
and thanks for your help buddy.
Old Sep 11, 2010 | 03:32 AM
  #66
turd.ferguson's Avatar
in the video...was the warehouse spot over at kitchen kompact?
Old Sep 11, 2010 | 06:02 PM
  #67
jimmyjun's Avatar
hey max hughes, make a diy for the rx8 tb swap. everybody here is interested....... thanks!!!!!!!!!!!!
Old Sep 11, 2010 | 07:04 PM
  #68
mileoutrage's Avatar
Deff intrested, every little bit counts, what is the exact mm size compared to ours?
Old Sep 12, 2010 | 04:02 AM
  #69
jimmyjun's Avatar
rx8 TB is 70mm and our oem TB is 58mm or 60mm.
Old Sep 13, 2010 | 04:15 PM
  #70
I want dyno numbers matt!
Old Sep 16, 2010 | 08:42 PM
  #71
chrischoi's Avatar
In for dyno.
Old Sep 19, 2010 | 10:23 PM
  #72
kradstct's Avatar
so for a header would a 4 into 2 and then in too 1 help in na more then a 4 to 1
Old Sep 20, 2010 | 12:04 AM
  #73
No, four to one equal length with a merge collector.
granted this is not a tc header, but the design would be optimal for NA build
like so
http://www.importpowerhouse.com/imag...F_B-series.jpg
Old Sep 20, 2010 | 07:51 AM
  #74
TJKASS's Avatar
4-2-1 will net some torque but no hp unless tuned properly for the exhaust pulse characteristics, which none of the aftermarket ones for our cars are. 4-1 is the way to go.
TYLER
Old Sep 20, 2010 | 08:40 PM
  #75
kradstct's Avatar
ok i was going to make my own header and just trying to get some ideas before i make one and wat size would be best for the piping
Old Oct 19, 2010 | 02:52 AM
  #76
m6ar2cel6oTC's Avatar
bump for update?
what wires did you have to switch around to get it to work?
Old Oct 19, 2010 | 09:41 AM
  #77
pwee08's Avatar
x2
hope the car is running good would like to see what the car puts down
Old Oct 19, 2010 | 11:44 AM
  #78
C4NN0N1001's Avatar
Bump! Wanna see some numbers. Was the time and money worth it?
Old Jan 5, 2011 | 05:56 PM
  #79
TimmerTC's Avatar
Bump. Updates?
Old Jan 5, 2011 | 08:26 PM
  #80
tneely's Avatar
Originally Posted by TimmerTC
Bump. Updates?
Agreed. How do the BC cams run? Aren't the stage 3 designed for a fully and engine and a turbo?
