NY state Inspection woes
Old Nov 17, 2011 | 02:27 AM
willerdcraft's Avatar
Default NY state Inspection woes
Hey guys its that time of the year again.
The NY inspection is due this is my first inspection i will be under going with a boosted Tc.
My check engine light seems to come on exactly every 200miles.
some people i have heard from (not scion people) say it takes about 100 miles for the ECU to be ready for emissions testing is 200 this long enough for the ECU to be ready ?
is there anything else the mechanic will be looking for with a car i still have one CAT?
Thanks for any input
Old Nov 17, 2011 | 02:32 AM
Roller_Toaster's Avatar
What cel are you throwing? Do you have a CEL eliminator on your secondary 02 sensor?
Old Nov 17, 2011 | 03:50 AM
Yea i have a CEL eliminator. i don't have a OBD tester going to take it to autozone when it goes off again
Old Nov 17, 2011 | 11:49 AM
my06tc's Avatar
make sure you know the ppl very well at the inspection place,if not they will screw you,but normally the cel cant be on for inspection,no matter what,
Old Nov 18, 2011 | 03:50 AM
ESEMRFOZZ13's Avatar
use something like scangauge, it will say "ready" or "not ready" when you scan it. smog station will not test if obd says "not ready".
Old Nov 18, 2011 | 12:39 PM
MillerRS1's Avatar
In NYS CEL = No pass its bc it goes into the computer I have a turbo on mine and I have a CEL Eliminator in the 2nd o2 sensor. Just get the code checked at Autozone or w.e and dont pull the battery bc you need to drive 200 miles to get it to reset or they won't even inspect your car. I also work at a stealership so I know what I needed to fix. Almost anything can trip ur CEL so it may not even be an o2 problem but the closer you get to the end of the month the more your going to get screwed bc they will pull ur inspection sticker. Luckily you dont need to pass an emissions test hopefully they dont care if your missing cats bc those are just visually check. Most places do not as long as your not throwing a CEL.
Old Nov 18, 2011 | 01:06 PM
Irishguy0224's Avatar
Off topic, but where the hell in fairport do you live? I wasn't aware of any other boosted scions in this area? hahaha
As for the code, we cleared mine and another boosted scions by clearing the code, and driving 50 miles WITHOUT going over 3k RPM. Drive slow and shift low, that should help clear it. Once you get to 50 miles go get it inspected. We are lucky enough to have a friend who does inspections, so he looks over the whole no cat thing.
Old Nov 18, 2011 | 06:53 PM
MillerRS1's Avatar
Most places will drive ur car to make sure its not going to throw a CEL even if they're just pulling it into the garage they get on it. Its most likely an easy fix....
Old Nov 19, 2011 | 12:49 PM
my06tc's Avatar
just tip the gie before hand and after and youll be good to go
Old Nov 20, 2011 | 02:57 PM
MillerRS1's Avatar
Well not every place does that bc of the fine from the state that would come on who ever inspected it for manipulating their system is BIG! I work at a dealership ive seen/ heard it all. I would just fix the CEL its prob just an o2 or vacuum problem.
Old Nov 20, 2011 | 06:27 PM
Carlanga's Avatar
scangauge will work to get rid of the light, but it will not delete all the codes completely from the system. I generally have to use a cheap autotel scanner for that, the one at AutoZone should work as well.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Oct 8, 2015 05:31 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
user9430961
Sep 24, 2015 01:09 PM
user9430961
Sep 15, 2015 03:16 AM
